I've been working on some candlestick holders the last few days. I had a particular look and feel in mind, where the top and bottom of the candlestick were left natural wood, and then the sides were stained. I'm using these Varethane "Premum" 1-Coat wood stains, that are kind of milky and flat colors. Such as Antique White, Vintage Aqua, Carbon Gray, Worn Navy, Foghorn, etc. They are not your normal stains, really...they have more pigment. I had hoped for a slightly thinner finish with them, but I think I can sand them back very lightly to get a slightly more translucent look. Once I do that, though....
When it comes to handling, I am not really sure if the stain alone, will hold up well to handling? If not, is it possible to use an oil finish (in my case, I'd want to use Tung oil) over the top of a stain finish? I've never done that, and not sure if the oils might cause problems with the stain. The can states that the stain uses "nano-pigments and soya oil", so they are oil-based stains. Maybe since the stain is oil based, that will be good enough for handling? I suspect they could be handled a bit by potential customers, since they are candlestick holders, and candles would need to be swapped out periodically regardless, maybe also seasonally.
Oh, I guess that's another factor. I am not sure how the stain might hold up, to dripped wax. The Tung oil I know is quite water resistant/proofing, and I used it on the bare wood parts of these candlesticks to provide a barrier between any dripped wax and the wood. I was kind of thinking the same thing, for overcoating the stain. (At the same time, I kind of like the flat look of the stain...and now I wonder if overcoating the stain with Tung oil would ruin that look and feel...)
