Oneway 2593 #2 Taper Safe Driver
Tallahassee, FL
Does anybody have a Oneway 2593 #2 Taper Safe Driver? Did it come with a tool to adjust the tension on the tip? I recently purchased one from an online vendor (not Oneway) and it arrived open package with no directions for care, adjusting or removing the tip. Because of the open package I'm wondering if something fell out. I checked the Oneway website and couldn't find information on what shipped in the package or directions for adjusting the drive. Thanks all!
Here are all the info and instructions.
The screw is inside, look with some light in it, and on the side it has the setscrew that lets the pin slide back and forth against the spring pressure, if you take that screw out the pin will come out and the spring also, you should be able to see that the screw is in there, otherwise you will look right through if it is missing.
