bought a Oneway coring system. each of the knives has the Oneway brand carbide tip - not the koror. It was an inexpensive upgrade when buying direct from Oneway and not a dealer.
I am concerned that when coring wet wood the carbide tip and screw will over time get stuck in place with rust from the moisture in the wood and that the screw won’t be able to be removed When the carbide tip needs replaced. So is it necessary to remove the carbide cutters and screws after every use Before storing? has anyone experienced this probl‘‘em with tips or screws rusting in place On the )Oneway knives? ZOr do you use some sore of grease or anti-seize compound? any alternatives to buying a whole tube or container of anti-sieze for this small limited use?
Please don’t fill this discussion with replies on your experience or use of the Korpro and its benefits. I am fully aware of it and its benefits. It’s just not in the budget at this time for the limited use we will have with the system as it’s not in my budget.
