Among the videos I plan to do, I will cover the coring systems. As far as the Oneway system goes, on the plus side, it is rock solid, all the way to the full extension of the largest blade. On the minus side, in my opinion, worst ever cutting tip design ever. Many have switched to the cutter from Mike Hunter which is a bit spendy, but people prefer it. I did buy one of their tips years ago before they ground it down. I ground the end to about 65 degrees, and it was trapezoid in shape, so cutting edge and base were parallel, and sides tapered down to thinner, about the thickness of the support blade. Far better coring speeds, and cutting action, and you didn't have to remove the tip to sharpen it, just a quick touch up with the diamond hone. The "theory" with their cutter shape is that the spear tip breaks the fiber and the sides of the cutter cut the fibers away. To me, that doesn't even work in theory.... I prefer the McNaughton which has a "learning curve". I think the Woodcut system is better than the Oneway.
