Oneway Jaws (Talon and Stronghold) - Perfect Circle
Cambridge, MA
I'm in the process of designing some carriers for my jaws. I like to store my jaws in a tray, off the body of the chuck and for those dovetail jaws, at the perfect circle diameter.
That perfect circle is the ideal dimension of the tenon when gripping,
Does anyone know what these diameters are? Oneway doesn't list them (Vicmarc does in contrast)
I have a lot of jaws and if anyone has measurements to share, that would be great!
Thanks
Thanks for trying but I have that info ;-*
If you look at the table, Oneway mentions the 'design diameter' (lower left of page)
That's the number I am looking for. It's the amount that the jaws have to be opened in order to grip a perfect circle (with the dovetail jaws)
For most manufacturers (e.g. Axminster) that's about 1/8" because they make the jaws from one billet and then slice it across to make the 4 jaws. I don't believe Oneway does this and so I am not sure.
I can eyeball, but if I could get the actual, that would be preferred
Thanks
E
For me the answer was more chucks, as I found chnaging jaws tedious and I often dropped the screw into the sawdust. OK now I have a chuck cupboard :)
I have the One Way dovetail jaws what I did is clamped the woodworm screw in and measured the diameter then use that when making the dovetail tenon, while that may not be perfect it does the job.
As far as storing the jaws I don't worry about it, I have 2 Strong hold chucks one of them has the larger dovetail jaws installed and the other has the smaller jaws (not the dovetail). The
Ok, now I understand the dimension you want. It could be relatively simple to calculate perfect circle diameter from the listed closed circle diameter for the entire Oneway line using only one kerf measurement.
1. Measure the kerf from the Oneway machining process by setting a Oneway jaw set in a perfect circle and measuring the gap between adjacent jaws.
2. Create a spreadsheet that calculates the perfect circle diameter from the fully closed diameter by:
a. calculating the fully closed circumference from the fully closed diameter listed in the Oneway data sheet (2*pi*(d/2));
b. adding the kerfs (4*k) to the closed circle circumference to approximate (because the kerf measurement was linear) the perfect circle circumference;
c. calculating the perfect circle diameter from the perfect circle circumference.
If you are familiar with spreadsheets, then this is a 15-20 minute task. The assumption is that the kerf is consistent across the entire Oneway line. I measured about 1mm for #2 tower jaws with a steel ruler and not much care (about 3mm for the largest Vicmarc jaws). You might decide to use calipers.
The method I used, which I explained in reply #5, will give the perfect circle and that can be proven simply by positioning a tool rest against the dovetail and rotating by hand or if you want to get really picky setup a dial indicator.
Ed, I think that the dimension you are looking for is on the Oneway webpage that Holmes linked to above. The dimensions on that table appear to be the "design diameter" of the jaws. If you look at the schematic on the right side of the page, it says that the "A" dimension is for compression chucking (that is, on a tenon), and the description of this dimension on the schematic is "Use this measurement when grabbing on to a tenon". I doubt that Oneway would describe the dimension that way if it were not the perfect circle dimension.
I am not at home so I can't check the dimensions in the table against my Oneway dovetail jaws to confirm this, but I have always used that table for my perfect circle dimensions.
Impressive. It never stops amazing me the creativity I see when a solution is needed for a desired outcome.
@Edward Kerslake I dont quite understand why you need perfect circle dia for the storage containers, unless you print that value on the container. Appears you label with the range provided by the mfr, which OW provides on their site. OD of the jaw plate would tell you the min hole size for the container. Just curious. I used to store mine in a similar manner.
Those are very nice. I'm sure some of us would appreciate having the stl files made available on Thingiverse. Maybe someone could create an stl for the elusive Stronghold jaw mounts with the Vicmarc jaw bolt configuration.
I use the dovetail jaws which have much better grip when close to perfect circle (plenty of posts will explain why)
By storing them that way, when I have a turned tenon, I can eyeball the jaws that will fit
I've spent the past two weeks working on these CAD models and am pretty happy with the results.
I have a stack of prototypes that I plan to give away to local turners too ;)
I tried a bunch of different designs; using just the keyway at the bottom, just a flat circle and ultimately the final design of
(1) Final circle that matches the outer diameter of the jaws when at/near perfect circle (about a 3mm gap between jaws)
(2) Using the keyway at the bottom as a recess to hold them flat
(3) Using a central cone and cross to keep them separated and pushed against the outside diameter.
NOW, I am happy :)
Still working on my Stronghold jaws, but the TALON ones are done.
The lips are sufficiently high that these can be stacked (I stack the #2 jaws that come with the Talon chuck as I have multiple!)
I have uploaded these to Creality cloud for non-commercial use.
NOW, I am happy :)
I have 2 Strong hold and 1 talon cuck and with either size I clamped the woodworm screw in place bring a tool rest up to just touching the outside of the jaws, turn the chuck with the handwheel and that verifies the perfect circle. I have access to AutoCad but why bother. I also have an adaptor to mount the woodturning chucks on the metal lathe that I used to turn off the bird beak on the outer diameter of the profile jaws and that was further proof that clamping the woodworm screw produced the perfect circle.
I checked the files and they were marked as $1. That was not my intent and they are FREE models. I have modified the files as a result to ensure free of charge.
Download and play with them and let me know if you have issues or see opportunities for improvement.
