Oneway large outboard
Huntington, VT
For those who have one of these attachments with an auxiliary tailstock riser, how far do the standard and long outboard tables extend from the headstock? Is the standard length short enough to turn typical bowls while facing the spindle and long enough to get effective use out of the tailstock? I bought a used 2436 with an extra long (10'!) table and am contemplating cutting it down to a more practical length for my shop. Also thinking about adapting the cutoff section for occasional use by joining the sections together (alignment issues?) or boring new attachment holes and swapping it out with the shorter one if needed. I saw a custom built bowl lathe with a detachable tailstock support recently so I know it can be done. My primary interest is in larger hollow forms but having a short bed for easy access would be nice.
This is what I have. Cost $190. May be more than you want to spend but it does the job.​
With a piece of angle iron you can make it the length of your bed
Pat
T28011 Bowl-Turning Tool Rest​
Upgrade and minimize moving your existing tool rest.​
Want to turn something larger than your lathe swing, such as a bowl or even a round tabletop?
Want to turn long spindles without needing to change tool rest positions?
The 33” long T28011 Bowl-Turning Tool Rest comes with everything you need for mounting to nearly any 14” to 20” swing swivel-head wood lathe.
It will allow you to turn workpieces up to 30” in diameter and you’ll be able to turn those extra-long spindles like a boss!
The Grizzly Technical Support team is U.S. based.
Parts for the tool rest may be available online and shipped from the Grizzly parts warehouse in Springfield, MO.
Note: This is the tool rest only; the lathe is not included.
