Oneway Vacuum Chuck Adaptor
Status
Not open for further replies.
Bloomington, Illinois
Oneway Vacuum Chuck Adaptor. Screws into outboard side of headstock allowing a vacuum to be drawn through it, while preventing the hose from spinning with the spindle (vacuum pump and chuck required and not included). Uses the same Taper-Lock Adaptor as Oneway Stronghold chucks, so you can easily change to different size if needed simply by changing the adapter. Included is the adapter that fits the Oneway 1224 lathe (¾” - 16tpi RH). Works fine. $50 plus shipping. Located in Central Illinois.
HandKraftedbyMatthew@gmail.com
-SOLD-
Status
