I have a wolverine sharpening jig system. Is there a after marked platform available to sharpen negative rake scrapers?
www.rightanglenow.com
With the Oneway jig, many have cut a notch in it to accommodate the 1 1/2 inch wide CBN wheels. They are seldom dead flat, so surfacing them may help as well. The Right Angle set up is pretty good, especially if your NRSs have different angles like the ones I use, which are 30 and 60 degrees on my robo rest, which I do not make any more. D Way does like to sharpen the cutting burr on their NRSs up side down saying that it makes for a cleaner cutting burr. I am not sure about that. As for size, They are plenty wide for sharpening scrapers of all sizes, at least for me.
I wrestled with the same problem. I use the Wolverine System with the mini-platform as close as I can get it to the wheel.I have a wolverine sharpening jig system. Is there a after marked platform available to sharpen negative rake scrapers?
The Wolverine platform is wide enough to sharpen any turning tools I've needed to sharpen. I have a problem of it being too wide for some, particularly when they are very short. That is where I use the mini platform. Large scrapers should work fine with the standard platform.
@Odie , what’s the stuff zip tied to the support for? Looks like a block of wood with a rubber bumper and screw in the end, plus maybe a bit of sandpaper?
https://stuartbattytools.com/ I can highly recommend Stuart Batty Tools. Cindy Drodza is one of my mentors. She uses his system religiously. He also taught Cindy how to sharpen her own line of Signature Tools. Yes the platforms are expensive but they are second to none. You buy this platform you will never need another. Check out Cindy Drozda Signature tools as well. Good Luck!I have a wolverine sharpening jig system. Is there a after marked platform available to sharpen negative rake scrapers?
I personally think there is way too much thought put into the angles for NRS. The precise angle really does not make much difference.
