Open segment ring calculator?
Irvona, PA
originalrevolutions.com
There are several calculators that work well with closed segment rings out there but, are there any that will help calculate the dimensions for an open segment ring?
As a newbe segmented turner and a newer open segmented turner(currently working on my third small project) I have used both Segment Project Planner and the Woodturner Pro suite and I prefer Woodturner Pro Segment Pro. So easy to use once you do a few projects.
You can design shapes and profiles along with degrees of open segments.
