  • Congratulations to Guillaume Fontaine for "Méandre 2.1" being selected as Turning of the Week for August 25, 2025 (click here for details)
Oval bowls...(again)....
Seattle, WA
I'm making a set of oval bowls. A few test cuts to verify the most pleasing oval shape.
The "optimum techniques" thread got me to thinking, what's the optimal way to make an oval bowl? The Vicmarc attachment at around $3500 plus that much more for a lathe large enough to use the attachment? Then add in gouges and a$$ociated sharpening equipment. After all that expense you've still got a difficult machine to work with.
The picture shows two degrees of oval-ness in maple. the other is test cut in rough desert iron wood that the oval hardly shows up. Note the smoothness and no need to sand. Cuts were made with 2 flute HSS ball end mills (better cutting geometry than wood router bits).
A few years back I posted about this and a lynch mob came after me. "It's not woodturning" blah, blah, blah. So what? A good many of the art pieces published in the journal aren't turned either. Anyway, I have the feeling a number of the forum regulars now have CNC and more are sure to come.
I think that attitudes toward non-traditional work are changing, and that more new techniques are being embraced. I base this on what I see being posted here and the comments on it. Even though I'm a "traditional" turner, it's mainly because of my limited skill set, not because I don't want to branch out and do more.
....and yet another method - My elliptical work is all non-CNC:
Tim
I will have to search for it but one of my books had plans for a wooden oval turning attachment. As I remember it wasn't that hard to build. I'll try to find it. Other than that carving it is the best option. I found it
