Pawlonia or Paulownia
Burnt Chimney, SW Virginia
www.burntchimneystudios.com
While cutting up some old logs that needed to be cleaned out I realized that one of them was a pawlonia, or is it Paulownia, log that was in great shape. What do woodturners normally make from this wood? Bowls? It seems too light for boxes. Ornaments? Google showed a sight that makes pipes. Is it good for carving?
Then, while walking the perimeter of our property I realized that our neighbor, who has just joined SMLW, has the equivalent of two or three pawlonia trees cut up and lying around on his property.
I look forward to your suggestions.
On about last February 11th there was a thread on Wood Central about this wood. You can go there and check it out. Seems there's a big difference between how the tree is grown because if it grows fast it winds up like cottonwood.
Good Luck
I have turned Paulownia and found it to be very stable. You need to keep your tools sharp as the wood will chip out. It sands very easily and finishes nicely. For added interest, the pith holes can be left in the piece without any problem.
Paulownia bowls
Ed,
I've turned some bowls from Paulownia. I agree sharp tools will leave a surface wihc requires minimal sanding. I finished by wet sanding the dried bowls with a linseed oil / mineral spirits blend, leaves a very pretty sheen.
Happy turning...
Frank
