Photo setup critique needed
Huntington, VT
I need a simple, effective system for documenting my work. Like most people I don't have room for a permanent setup but this is what I have cobbled together so far. The first pic shows the finishing corner behind a cnc router with a cover sheet on the bed which I use for an assembly bench. The second shows the cover sheet slid over and supported by the router and a couple of bench/carts with a white backdrop slung from a pole suspended in front of the exhaust fan, The lighting consists of a single 5500K compact flourescent with about 3400 lumens behind a white parasol for diffusion and a couple of white bounce panels. The windows are covered so 95% of the ambient light is shut out and whatever daylight makes it in should not conflict with the photo bulb. The front of the table is about 9' from the back wall, allowing the backdrop to drape gradually. I have a DSLR camera with a 70-210 zoom lens which allows me to set it up far enough back to have some room to maneuver.
The third photo is a test shot with 105mm focal distance, auto white balance and f18 aperture. The color seems right, but I may compare it with a custom white balance and a designated color temp just for grins. The image of the vessel itself seems fairly clean. I see some wrinkles and schmutz in the flat backdrop, more shadow than I might like and a hot spot on the vessel shoulder. I could get the vertical background darker with a shade panel between it and the light. I'm sure the wrinkles could be rubbed out with editing software. I have another lightstand so could easily add another light if advisable or another diffusion panel.
What do your eyes see that mine don't, and how would you suggest changing things around?
Kevin,
This has served me well for years. I used PVC pipe and fittings to make a cube, covered the sides with a thin white cloth (that doesn't collect dust) and hold it on with safety pins, and cut a piece of (usually) neutral grey board to start flat on the bottom and bend upwards, clamped to keep the bend. This give a seamless background. (I like that mat board better than rolls of thiner backdrop paper since the paper can show wrinkles such.)
I set the whole thing on a workbench or my tablesaw top. Most of the 3-way corner PVC fittings are not glued so the pieces come apart easily for storage. A board on top lets me suspend things from a fine wire if needed.
Some photo pros say to stick with a single light, but I prefer two: I use two daylight photo CFLs on adjustable bases, the light diffused through the cloths on the sides of the cube. I position the lights closer, further away, higher/lower, forwards or back according to my mood at the moment.
I use a third light on a flexible arm with a diffuser on the front. I wish it had variable brightness. I used to tape a piece of tissue to this lamp but now use a soft box diffuser make for strobe lights on a camera: https://www.amazon.com/dp/B003Y30334
This is without the softbox diffuser on the light in the front. The softbox does makes shadows less harsh.
I use a digital camera on a tripod or sometimes just snap a shot with my cell phone camera
One VERY important thing: turn off all other lights in the room. If not, they can compete with each other and change the color of the light. Best to cover any windows.
I move the side and front lights to suit my mood at the moment, and sometimes substitute a different color of mat board, always going for a neutral color that doesn't detract too much form the subject. I'm certainly no pro but I can usually get photos that suit me. Sometimes I'm not too picky!
For this one I was going for a more dramatic contrast.
On some of these I used a more even lighting. Some could use some editing but that's life.
Before I built this I used the same type of mat board and improvised with a chair for a stand. This gave more trouble with color temperatures as ambient light changed, but worked fine. Again, I prefer a seamless background.
I almost always adjust some image things in Photoshop/Photoshop Elements to edit, crop, size, remove dust, etc. (Photos from most cameras and phone cameras are WAY bigger than needed for sending by email and posting.) And to get past the 4-photo per message limit on this form, I like to make composite photos which can show lots of things but just count as one!
It seems like you have some dirt or dust on the camera sensor. Those out of focus blobs in the top right and bottom left quadrants are the result. I'm not sure if that is something that is user fixable on your DSLR, or in need of a service technician.
One thing I've found is that post processing goes a long way. And that I don't know nothing about it. But you know who does? ChatGPT. It'll tell you about all the settings in your editing software and which ones to adjust etc.
Ha! I've never once used any of the so called AI programs but I have used Photoshop extensively in my work since version 1. Almost second nature now. A tip: Photoshop Elements has maybe 95% of everything useful in the full version. Amazingly powerful. I suspect other editors are as well.
Will, I believe you are right. I will talk to the camera shop I bought it from (used) recently. Thanks for pointing that out.
I see sensor dust also. Most times I can get rid of it by using a squeeze air bulb on the sensor. I also always post process using free Gimp and the spots are pretty easy to get rid of using the clone tool. Since I post process I dangle a white balance card up in the corner. This allows me to get good color in the post processing and I just crop out the card.
Your setup looks similar to my arrangement.
I used GIMP to clean up a bunch of mediocre photos when I assembled my website. It can do a lot, but it's like sanding a mediocre turning. I would rather start with a well-lit shot that doesn't need a lot of cleanup. I'll leave ChatGPT to the lawyers who need bogus citations to bulk up their filings. Any suggestions on how to improve the setup as shown would be very welcome.
I did speak to a former pro photographer at our guild sawdust session this evening. He suggested another light and/or shinier reflector boards and more scrim material for better control of where the lighting lands on the piece, as well as trying a different background paper that will drape more cleanly. He said that more light was better in a pro shoot because you could have shorter exposures that were less susceptible to vibration. He also leafed through some Fine Woodworking mags that someone was giving away and pointed out various lighting and editing techniques and the variations in light intensity on the subjects of various shots- very illuminating. I need to develop my eye to make best use of his advice.
I really just want a convincing, repeatable and easily set up arrangement that will suffice for a website or gallery submission. The photography rabbit hole may be deeper than the woodworking one I am in.
Kevin without setting up permanent place for photos one of the easiest things to do is setup a stand or chair like photo above and set it up outdoors on a overcast day. I have dual soft boxes with CFL bulbs But I was never satisfied with the results. I ended up buying a setup from Cowboy Studios (which seems to be non existent now) that uses strobe lights. It was a little over $125. I cannot find a comparison setup that does not cost 5 times that now. But there are strobes on Ebay that are very fairly priced. Initially I would set it up in the kitchen or living room and wait until I had a bunch to photograph, not very convenient for a quick photo. So I found a spot in a store room in the basement and now have a permanent place. I sometimes use this little LED photo tent for small pieces. Small photo tents can be had on Amazon for about $10. Large photo tents can be had for under $30. Lots of clubs use these tents for pictures.
I
Thanks, Kent. I tried a different setup like the one in your link, using my cellphone on a jerry-rigged adapter as the sensor on my dslr seems to be scratched. I used a different backdrop paper and set the vessel closer to the back curve which subdued the wrinkling. It lessened the gradient though, despite using a shade panel at the back of the tent. The first shot shows the setup, the second with a main light on the left and a fill farther away on the right, the third has the fill light in closer. Having two lights is a bit easier to control than one. The setup is pretty quick to put together. The depth of field seems less with the phone's camera and it is less convenient and controllable than the dslr. I feel I am getting closer- any comments?
CFL lights are terrible for photography. They have a low cfi (color fidelity index, I think). The big issue for these bulbs is that regardless of being called daylight, warm, cool, they have a big green spike from the mercury. Your photo software or camera cannot control for that. It skews all the colors. There are high quality led lights with very high cri. Your colors will be brighter, more vivid.
Shadows are fine, and can be very nice. One shadow only. We, as animals are used to one big light source, hence one shadow. I suggest that you harden your main light and place it nearer your camera. Your fill light is ok on the side as you have it in the last images. A fill light is used to fill the black shadow created by the main light.
A hot spot is undesirable if it’s totally blown out, but the reflection of the light source is fine and desirable. The only way in a photograph to show the finish quality, whether mat, satin, semi-gloss, gloss or mirror shine is the bright spot. Mat shows nothing, satin/semi-gloss shows a soft, out of focus bright area, and gloss and mirror will show what the light source is.
Your first photo is more compelling than after you fixed it.
The lighting is looking good!
Several comments:
One, it's really difficult to hold a cell phone perfectly horizontal while taking a picture! Some phone cameras have a horizon detector that puts a line across the screen when the cam is horizontal. When not using my Canon DSLR, I often use a little spring-loaded cell phone holder that mounts on a tripod. (This is great to take photos of me working on something by using the 10-sec self timer.)
Two, cell phone lenses are usually a little too "wide angle" to suit me. When the lens is close, this introduces distortion in the image. I find I sometimes get a better picture by moving the camera physically back away and zooming in - the object may be the same size on the screen but the perspective is a bit different. This is the reason pro photographers often use a "portrait" lens when shooting faces and people - if a "normal" lens is 50mm, a portrait lens might be about 105mm. It tends to make a more flattering portrait with less distortion on facial features. Might try it both ways. When I shoot an object I usually take multiple photos from different distances and heights, and often rotate the piece to different angles - decide what I like best later.
Also, I do post processing on almost every shot - send the image to one of my computers by email if I don't want to bother with connecting by USB, then load into Photoshop Elements. This lets me straighten images I when I accidentally tilted the camera a bit, crop to what I think is a pleasing boundary, and make minor corrections on brightness and contrast. (and remove spots of dust or whatever that showed up on the backdrop.)
Then I save the file in a reduced pixel size in a folder called I call "for posting" since web pages and email don't usually need pictures with 4000 pixels across! Most target and transfer software will do some of this automatically but I'd rather keep the control it myself.
Keeping up with photos can turn into a nightmare. For woodturning photos I put the photos in sub-directors with names that make sense: tools, wands, ornaments, etc. I save the originals in the original full resolution, unedited form in case I need them later. (That's probably one reason I had over 70,000 photos on my drive at last count! .... and don't forget to backup everything!)
I give each image file a name that is useful for searching, but leave the numerical name the cameras usually generate at the end of the file name so I can find the original easily if needed.
But about all this remember one thing - I'm a card-carrying, certified hopeless photo maniac! You should see my boxes of slides and film and file cabinets of prints from past decades - digital makes things SOOO much easier! (and incredibly inexpensive)
And remember, take advice on the number and type of lights and other things from me or others with the proverbial grain of salt. Everyone has an opinion. Do what looks good to you. There official credentialed photo police do not exist in art. And almost ANY picture is better than no picture.
Can't wait to see more of your photos!
Oh a little story about "shooting" photos. Once a 4-yo grandson stayed with us and at bed time I told him I might not be there when he got up - I had to go shoot a wedding. He was shocked: "WHAT, what did you say???" I had to explain that "shooting" a wedding meant taking pictures with a camera. :)
I had to clear up the same terminology by text with a young friend in Italy learning English - when can the word "shoot" be used? Shoot me a text. Shoot a photo. Look at this shot. Shoot the moon. Shoot at a target. Oh, shoot, didn't mean to do that. These tires are shot. A young shoot on a plant. The car shot forward. And when the friend visited we took her to DC and she shot 100's of photos - has a very good eye for composition, lighting,!
Thank you, Marc. When you say "harden your main light", what does that mean? I can remove an extra layer of scrim over the tent I put on that side to soften that light.
Do you see evidence of a "big green spike" from the cfl lamps in these shots or is that something that would be evident only from comparing the same shot lit with higher cfi (cri?) bulbs? I am using 5500K cfls sold for photography use from a local camera shop, but they don't have a specified color index- I guess that correlates to buying a dust blower without a fan curve. I hesitate to invest in more lighting at this point until I develop a better eye.
I appreciate your point about natural shadows and bright spots.
A dear friend of mine, sadly now passed, who lived at an upscale retirement community used to complain about fluorescent lighting. The dining room had been lighted with incandescent lights,,then for energy savings switched to fluorescent. He went on a campaign to get them to change back. He claimed that the food looked grey and unappetizing, and that the residents, all old, looked dead. We need as much color as possible!! was his complaint. He finally won.
So, that’s the big issue. The vibrancy of color. Not having things look like liver. In my reading before this response, I note that there are fluorescent lamps, high end stuff for photography somehow has gotten around some of the limitations and sport a high cri. I’m dubious, but what do I know?
Regarding hot, or bright spots, consider portraits. Catchlights, the bright spot in the eye of the model is important as it gives life. Photos without a catchlight tend to be less compelling. Generally photographers are keen to have their subjects, while in shadow, looking toward the sunshine , or to use flash to get the catchlight. I think it’s similar when photographing objects. It’s good to add life.
These are examples of using hard lights, no diffusion, to create a hard shadow. Not everyone’s cup of tea, I know. The effect is to add drama. Our eyes/ brains are quite attracted to contrast- bright highlights and dark shadows. It makes us curious, so we look around and spend more time viewing. Additionally, a single hard light is the way to photograph chatoyance. Soft light or light from two directions disappear it.
I hope my notes are of some help.
I have a very simple setup that only requires me to clear off my workbench. The backdrop is a 4ft wide roll of grey paper (Hobby Lobby or Michaels) . I have good LED shop lights above and also have an overhead dentist style light with a 150wt equivalent LED Flood that I can easily move to highlight the work in different ways. Takes me only a few minutes to set up and is easy to store. Link to my gallary
I
View attachment 77120View attachment 77121View attachment 77122
Kevin although the second sets of photos takes away most of the shadows the first photo is far superior as far as being sharp. Even though the very first has what looks like dust spots the actual piece looks really good. I think that the camera with your second setup would be the best. The dust spots can easily be fixed with Gimp and the clone tool. I have always wanted to show the piece in the best possible light. I want the people to see the actual piece and dramatizing it takes away from that. Also I use Canon DSLRs and I've bought a couple extras from Roberts Cameras on Ebay, of the 3 I have bought the most expensive I bought was $63 and the other 2 were cheaper. All three function great and all I needed was to purchase new batteries for 2 of them. One of them now sits in the storeroom on the tripod and is used solely for woodturned objects leaving my best Canon for normal use.
Thanks, Bill, The first shot was taken with a dslr at f18, the second set of shots were taken with my Samsung phone at f1.8, which accounts for the lack of depth of field. It appears the aperture is fixed on the camera phone. I dropped off my Nikon at the shop to see if they can clean the sensor (I tried) and hope to retrieve it Monday and try again.
...I dropped off my Nikon at the shop to see if they can clean the sensor (I tried) and hope to retrieve it Monday and try again.
Since some of the spots look out of focus they might be dust on the mirror, if it's an SLR with a mirror. I think dust on either external lens surface would be too far out of focus to see, but don't know. A lens swap could tell.
John, there is crap on the sensor- I can see it with an illuminated magnifier and it shows up in the images shot with different lenses. I couldn't clean it up but the camera tech claimed he could- we'll see. I don't understand how it could be the mirror as that flips up when the exposure is taken.
. I don't understandhow it could be the mirror as that flips up when the exposure is taken.
Oh, sorry, you're right. My brain was in vacation mode. And I've been on a permanent vacation since 2006.
I always worried about dust when changing lenses. I was taught to use a gentle little finger squeeze air puffer but don't know if that's recommended now.
Although the phone cameras have limitations, it still amazes me how good they are these days. I have one magazine cover published with a shot from a Motorola phone camera.
Hey, did you ever try holding a camera (with a small lens) up close to the ocular end of binoculars or a small telescope? It's amazing - I always have to zoom in just a bit to avoid vignetting and figure out how to hold everything steady and in alignment while focusing. (The exit pupil on small binocs is rather small.)
Here's an example. The first photo is of a moose in a small lake in Glacier Nat Park with, not a phone, but a tiny pocket Canon digital PHD camera (Push Here Dummy). The moose was sticking his head in the water and eating vegitation from the bottom. The second photo is from the same spot on a low hill in the woods but shooting through my little pocket 8x Leitz roof prism binocs:
I got down on the ground and rested the 'nocs and camera on a handy log. I was pleased with the result! The fun thing was back at the lodge where I talked with two guys wearing maybe $25k of photo equipment each, lenses as long as my forearm. I'd seen them out and about looking for wildlife. I asked them if they saw the moose. No, where?!! So I showed them these photos. When I told them how I got the shot they were literally speachless. :)
We've done this with astro photos too. Moon, sun (with good solar filter), comets. Got a decent photo of the Andromedia galaxy with an iPhone held up to the same binoculars.
Getting dust off of the image sensor is really a job for a camera specialist as touching that sensor can really botch up your DSLR. Usually a puff of air may help but sometimes it just pays to get it done professionally. I myself am not a phone person and the only time I have it with me is if I'm out of town by myself and I usually have a real camera with me. Recently about a month ago I bought a Dwarf II Solar Elite - Smart Telescope for astrophotography and there has not been a clear night here since I bought it.
Another go-round with a new camera. The blotches turned out to be dead pixels on the sensor. Fortunately the camera shop honored their 90 day warranty. Unfortunately for them the D80 listed in their inventory disappeared and they opted to replace it with a D700, so I wound up with a newer full-frame camera which apparently is well-liked by many photographers, including a new cf card and an extra battery. Maybe they missed the dead pixels before they sold the unit, but the manager said that could happen anytime. In any case, I was happy with the service I got- kudos to Junior at LeZot Camera in Burlington, VT.
Any more comments on these new photos?
Kevin,
That's supposed to be a great camera! (I haven't been to Burlington since fall of 2019 - oh the colors in the hills in that part of the country...)
I like the lighting on those. I like the overall lighting on second of the first two best. I can see the shape and the details in the wood all on both sides. The highlights nicely show the finish. (the highlight on the right of each might be moved down a touch) I like the point of view showing a bit more inside.
Consider raising the camera a tiny bit or cropping - the top of the turning looks a bit crowded in both frames - but that's just my preference. The camera looks nicely aligned horizontally. (Aligning by eye can be hard - in many cameras you can turn on a grid as a visual aid. I sometime tweak things in Photoshop if they bother me.) The first photo has a bit of a warm (red) cast, at least on my screen. The second also, but not as much. (I make sure I turn all other lights in the room off, cover any windows)
The third photo has a nice vignetting and a cooler (more blue) color cast - it might be lightened a bit with an editor. The finish almost looks matte absent a highlight - is it a soft finish?
I know there are some who strongly advocate always using a single light but I've never seen a pro who doesn't use fill light or at least reflectors in the studio (AND outdoors!) You should see what my son hauls to a shoot! I used to shoot portraits and have been a part of TV commercial shoots and I/they always used plenty of diffuse fill light - sometimes reflectors, umbrellas, light panels, diffusers. When I photograph turnings I'm trying to show the shape, color, detail, and finish - I'm not submitting photos to a guild panel for judging! Not doing magazine covers.
Dynamic lighting and backgrounds are nice sometimes but if not careful they obscure detail, both in strong shadows or by lack of contrast with the background. I've seen plenty of horrible photos and video (in my opinion) from "pros".
Keep in mind that I claim no credentials, just opinions!
If you like, I could pass these on to my oldest son for his comments - he has the best eye of anyone I know!
Thanks, John, good suggestions. I certainly could make use of your son's opinion. What I would really like is to get an experienced studio photographer here to mess around with the setup and show me how tweaking light placement, reflectors, etc. changes a shot. I hope to inveigle a former pro photographer from our club for a consult in return for turning lessons. In the meantime I will document my backlog and experiment with the setup.
Great! Sounds like you are serious about this. :) I'll sent copies of the three photos to my son in S Carolina. He's out of town right now so I'll get back to you when I can.
I like the way you think - get opinions and suggestions, experiment, experiment, see what works! (for YOU!)
When I take a photo I sometimes take 5 or 7 shots with different lighting, camera angles, move cam forward/back use zoom, then load the SD card onto the shop computer and decide what I like the best! Then maybe go back and shoot some more. (or just take a single shot with my phone when in a rush. 🤣)
I usually use a light grey curved background, but keep various shades of grey to swap out depending on the subject and wood. Hey, years ago there was a photo policeman on one of the other forums who would get seriously upset if anyone used a blue background, a kind of fad about that time. I personally don't much care for blue or any other strong color background , but I'd HATE to get arrested for using one!!
Also, there are a bunch of good books on lighting and photographing things, including "still life" as we do. I learned a lot from books, about video too.
And much on the web.
I hate to say it but your new camera has a dust spot just below the top center. When I blow up the photos there are what looks like multiple spots? Could the background have some spots on it? What John said about the first two that they could be lowered a bit is good but the rest is pretty good as there are no harsh shadows and all is crisp. For me the third photo is great and shows the work very well. With the setup you have you are getting the most out of it.
