You should check out the difference between stabilizing and casting with resin. As Darryl mentions, casting resin is normally used with a pressure pot, while stabilizing is usually done with a vacuum. The two processes use different synthetic materials as well. Since the stuff is pretty expensive, until you're more cash flush, you don't want to use the wrong stuff and waste it.
