Have a 3520A which has the Delta VFD B PU01 on it. The VFD is throwing an occ error code. I found the manual, in the troubleshooting section found this error code (occ), and checked the easy stuff - wire connections, etc. No bueno.
One of solutions is to increase the parameter for acceleration. I found the parameter (01-09) and it is set to 5, while the manual shows factory is 10. However, when I try to change the value the VFD displays ERR and does not accept any change to the value. Is there something programmatically that prevents parameters from being changed?
I can work around the issue by getting the drive belt super loose, starting the lathe and then tightening up the drive belt, but this is clearly not a good method. If I try starting the lathe with a tighter belt, the motor starts to turn, and almost immediately loses power and starts to coast down. There seems to be no braking in this situation.
At this point, I believe a new VFD is in order. I've searched around for replacements, and had experience with a TACO brand VFD that I used on a previous lathe. Basic question is beyond matching the 240 single phase input, and the 3 phase output for a 2 HP unit, what other specs are going to be vital? Several members here recommended a company called Dealers Electric, who does stock Teco VFD's and I found this one: L510-202-H1-U.
Curious if there are any other recommendations, or things to try before buying?
