I know most here probably do not mess with pens but I thought I would share this anyway. A while back I got this wild idea to use cactus to make a pen. Here are pictures of a couple of them.
This is a black resin cactus with satin nickel Baron
This one is clear resin with the tube painted black. It has a lot of depth and allows you to see into the skeleton.
The props are a piece of the skeleton that I cast with resin.
If you are interested in the process check out the tutorial I wrote here:http://builtbydoc.com/Pens.htm Follow the link at the bottom of the page.
Thanks for looking!
Thanks for looking!
