I have had this issue for 3-4 times in the last 4-5 years. (got it in 2003). problem starts by not starting with a quick press, and then takes increasing time and pressure to get the thig to start.
I called Clay several years ago and explained that I am machine illiterate and I felt like it isn';t making the right "contact" inside and that maybe I got junk on the perifery of the button that went inside. He said they are "sealed" and that isn't the issue. As I recall he was not is a good mood that day!!!! He walked me thru some things (after I had already used a cleaner) and it worked better til after I hung up. Then played with it a while and it got going fine.
So the last 2 days, again there is a pause when I pushed on the button, This worsened to the point I really had to press hard. Seemed like I had to press only at 9 o'clock to get it started. Then it wouldn't start at all.
I used a computer "Gas duster" to blow on the button-same problem, then a q tip and cleaned the recess, same issue. I used some alcohol, same issue. Then I sprayed silicone on the q tip and cleaned while depressing the button (machine unplugged!!!) . Then it started. After 2-3 tries it worked normally.
What is happening??? I have used it this afternoon and it isn't quite normal (sometimes a "quick" press isn't enuf) , but functions most of the time well. Have I done "bad" with a makeshift correction??? Remember me and electronics don't get along, because you can get killed changing a light bulb!!!
Gretch
