Problems with Starbond Med Black CA Glue
Glendale, AZ
Anyone (else) have problems with this specific glue?
I have tried 3+ bottles over time and they all are thinner than their other med glues and when I use an accelerator, it turns it into black water.
*I am not trying to fill thick cracks etc - using very little at a time.
Well, never used the stuff, but I do use Bob Smith CA glues from a local toy and hobby shop. Main reason is I started buying from them when I first got to town 56 years ago and I was making model gliders. I do not like to use accelerators. Main reason is that if I am filling a crack or knot, I want to make sure it soaks all the way down in. So, chase it with some thin CA, then add some medium. The thin stuff will wick the thicker stuff all the way down inside the crack to fill it all the way up. Another reason is that if you spray the top, then the rest does tend to "honeycomb" rather than stay solid. If it is a big hole/crack/knot, then I do it in stages. Hope this helps some....
