Pros vs beginners safety
Panama City, FL USA
Some of us beginners learn from YouTUBE, but we see pros do things that are seemingly unsafe. I see it as a real issue until you develop some sense of what is prudent. This is just a few things I’ve seen that seem like big NOs for me. Am I being overly paranoid?
1. Starting a bowl blank on a wood worm screw with lathe turning and holding the blank by hand
2. Turning with fingers hanging over the tool rest. A perfect setup to crush a finger between tool rest and wood.
3. Similarly, sanding using the tool rest to brace hand.
4. Taking a huge cut with a bowl gouge on an a rough bowl blank with no tailstock support with a relatively small tenon in the chuck.
5. Turning with no face shield or even safety glasses in sight.
I could go on and on, but are these folks just lucky or does their experience change the relative danger of this kind of stuff? and beginners trying to imitate without thinking through it.
I'm no pro but...
1. Pretty safe once you're experience and the wood is not got real sharp corners or bark etc... I do it at pretty slow speed.
2. I avoid this in bowl/hollowform turning. Spindle turning sometimes need to support the blank from behind so finger or two go over/under the rest to the other side of the spindle. Keep in mind sometimes the camera angles on you tube videos may make it seem like the fingers are between the tool rest and workpiece.
3. I don't and would only if sanding in reverse
4. Decisions that have to be made on your own. Individual decisions about what you're comfortable with.
5. My eyes earn my income so I'll pass.
Yes experience helps mitigate some of these things but with experience sometimes comes a certain level of complacency. On many jobsites it's the experienced people that injure themselves.
Safety decisions are up to you alone. If something makes you feel unsafe don't do it, find a different way.
YouTube pros aren't necessarily pros and they aren't safety videos. I believe the AAW has a list of videos somewhere curated for safety.
First a lot of the YouTube videos are best left unwatched. Many are done by folks who have never been invited to demo. They aren’t particularly good turners.
It’s been my experience that pros are very safety conscious. If they get injured and can’t work they don’t get paid
I do both of these I believe safely
The worm screw Mount. To me it is safe at low speed and if you have the reflexes to let go.
I cross the tool rest on bowls a little because I tend to have my forefinger behind the cut. I’m not going to get a catch so there is no danger of my hand getting between the toolrest and the wood
You can see this in a push and pull cut
As @Russell Nugent said spindles need finger support.
A huge cut with a sharp tool doesn’t put a lot of pressure on the wood.
90% , if not more, or youtube channels are not particularly pros - they're just in it to make money. If you see a so-called pro that is doing something you think is dangerous and they do not address that technique, then there's hundreds of other youtube videos to look at. over the last 5 years I have curated my own list of youtube channels (other than a couple of "beginner" level channels that I no longer find interesting) down to perhaps just 5 or 6 channels that I'll watch, and recommend to others - Granted some of them DO have videos out of them doing relatively dangerous things, but they also very often explain in great detail that it IS dangerous, and why they are using such a technique (and usually recommend safer means to do the job) Starting a blank on a woodworm screw with the lathe running, they're usually only running the lathe at less than 100 RPM anyways (which is slower than you could spin the blank on by hand if it wasn't for the friction) and have the reflexes and blank preparation (and hand positioning) to be able to let go as the blank tightens up, and then they'll also always stop the lathe, lock headstock and manually tighten up the blank anyhow.
As for turning with fingers over tool rest, a lot of times as you are getting into the *fine* detail cuts (very light shavings on a nearly finished blank, usually) you may find you *need* to extend fingers beyond tool rest a bit for that bit of extra control - but again that's with a "fine finish cut" and often not when roughing out the blank.
As for sanding, It also depends heavily on your technique and practice (and light touch) with sandpaper (and often there's A) holding paper to wood with a fingertip or two, and B) sanding been done at a relatively slow speed - Sanding something at 1500 RPM, you're going to dull your sandpaper to point of uselessness in a matter of seconds, so slow and steady wins the race there. (as any true pro will know from years of experience anyhow0
As for the HUGE CUTS you see them taking, most often they are working with VERY SHARP tools, so they're pro enough to at least be able to get a razor's edge on their gouges, and secondly they'll have the experience on cutting and locating a tenon on their blank that it is gonna hold VERY well (a 2" tenon can hold a 13" blank no problem, IF the wood where tenon is cut is sound & solid, the tenon is properly cut and sized, and the gouge is sharp, there's actually very little stress on the tenon itself.
and Finally, some pros DO usually have a face shield on (you may not see it in the video) but many will remove it for when they need to talk about what they are doing (otherwise they get weird echoey garbled soundtrack, and have to do a voiceover) and most pro turners that are well respected within our community DO have a face shield if not a full helmet at least for their videos. (I quickly lose respect for so-called pros that do videos without that all-important PPE)
As learned relatively quickly in my first year or two watching youtube (long before I got into woodturning, I was in small engine repair, and there's an untold number of complete blithering idiots producing popular, gimmicky youtube videos on small engine repair that do not have the slightest clue what they're talking about!) All you need is a video camera and a youtube account, and you, too can call yourself a professional "whatever", as long as what you say "sounds good" to people who don't know any better.
Many things can be dangerous when learning unless you have good instruction. A few I know about personally: woodturning, cave diving, flying aircraft, rock climbing, motorcycles, explosives, handling horses, high voltages, operating big equipment.
(1) Start slowly with a good instructor, learn the basics first from a human. Take classes, attend demos, find a mentor.
(2) Join a club: watch, ask questions, learn. Many clubs will hook you up with a free mentor.
(3) Buy some good books. Read every word, do all the exercises.
I learned much of my woodturning that way and can provide a short list of my favorites. (Consider it would take many, many hours of video to cover the information in one good book.)
Many youtube videos are bad, some are stupid, some are downright dangerous. I suggest not learning that way.
(4) If you want videos, seek out or buy DVDs made by respected experts. Some clubs have libraries.
(5) Join the AAW and look through their list of curated videos, examined and vetted for content and safety.
(6) If something doesn’t seem safe to you, don’t do it (regardless of what someone else says or shows.)
BTW, I have never mounted a blank on a screw chuck with the lathe running. I’m never in such a hurry that I can’t stop the machine and mount the blank by hand. That lets me make sure it is screwing on properly and I can control the tightness. (I’ve used wormwood screws but FAR prefer the dedicated Glaser screw chuck - it has many advantages, IMO.)
Using the hands can be perfectly safe and even preferable in some situations, even necessary for some types of turning. The thing to learn is when and what is appropriate.
Safety glasses are appropriate for some types of turning (e.g., turning thin spindles) but a good face shield is appropriate where some could be thrown at your face. As important for health in the long run is a good dust mask or better, a good respirator with P100 particulate filters. Don’t often see that in youtube videos.
A key lesson that I thankfully learned early from various mentors in flat woodworking, which I think applies at least as well to woodturning: if you aren’t sure about an operation at the lathe and/or think it’s sketchy or unsafe then you’re probably right, speaking for yourself! Put another way: many operations with power tools can be unsafe if you don’t (yet) understand what makes them safe versus not. This is a very valuable form of self-awareness to develop when turning!
Hmm, never tried cave diving... 🤔
It’s incredible, but not something to do casually.
For years my friend Carl and I drove from TN to northern Florida every couple of months to dive some of the fresh water caves. The water is crystal clear with temperature in the mid 70s I think, but due to the nature of cave diving we still needed dry suits with extra insulation. The actual dives were short, limited by the air we could carry (or stage spare tanks with multiple prep dives), however some dives were deep and required long decompression stops on return. We used double tanks with very long buddy-breathing hose/regulators in case two divers had to share air in a tight passageway. Mess up back in a cave and you can spend the rest of your life trying to get out…
It’s not an inexpensive hobby and takes specialized training. We both had years of previous experience in both fresh and salt water, lakes, rivers, ice water, diving with manatee, sharks and baracuda, wreck diving, search and recovery, etc. before deciding to take on cave diving. We learned specialized techniques to move, absolute buoyancy control. The instructors taught how to get out alive in the event of various staged disasters - for example in utter darkness with no mask, following a cord we had put in place on the dive into the cave. And were taught sure ways to discourage obviously open-water divers preparing to go into a cave. On some trips we’d mix in a little flying, aerial photography, drove around the state, explored the Everglades, etc.
Good clean fun!
No, you're not. You're just being observant and questioning what you see. That's basically just smart.
I rarely use a screw chuck, but this is fine in my book. Slow speed, let go when it's close, and tighten by hand. Would only do it with a (mostly) round blank - corners would be bad. Reason people do it is that it's easier to align and support the wood with 2 hands without trying to spin the wood or hand wheel.
If it makes you nervous, there's no real reason to try it.
Not with rough blanks or off-axis pieces - yikes.
I will use my fingers to support thin spindles, or the back edge of a thin bowl or platter.
I will use the tool rest - moved way back - to support one wrist when sanding thin spindles where a tremor or wobble would break it. But it's unnecessary and sounds dangerous for larger stuff.
I think this is totally experience-based. Large cuts in "cooperative" and wet wood, with a sharp gouge, at the correct presentation, are surprisingly smooth (and fun).
Also, it is surprising how small a tenon really needs to be if it is sized and cut correctly to fit the jaws (and in good wood).
But learning what you can get away with for both the cut and tenon does take experience.
That said, I always rough with tailstock support - but I am using an Irish/Ellsworth-ish ground gouge and the tailstock doesn't get in the way (much). With a 40/40 grind, you usually have to get the tailstock out of the way to make the cut.
I don't YouTube, but when demonstrating, I will use a face shield when I'm roughing things out and/or there's potential for corners of wood etc to go flying. But it really screws up the microphone and makes it hard to hear me talk. So I will often remove it when turning more predictable stuff. It's my calculated tradeoff for clarity of communication. And I try to remember to comment on my choice (but I probably do sometimes forget). The other factor for me is that the actual turning for the demo (and usually the wood blank) has been carefully chosen to make me successful in what I'm trying to communicate. So it's quite a bit different than grabbing a log out of the yard and seeing what happens. And I have no problem wearing a face shield for the whole demo if the venue/club requires or requests it.
But never without safety glasses.
This is a problem for beginners, as many modern beginners are relying on YouTube for their instruction. But there's nothing to go on other than their number of followers (which has nothing to do with the validity of instruction).
Is why you very often see, on this forum, recommendations to go find an AAW chapter club, and/or find a mentor, and/or take a class.
We demonstrators (and YouTubers probably) sometimes forget to think about our audience - are we demonstrating to an experienced group, or a bunch of beginners, or a mix? And we forget sometimes to comment on things that might be obvious to some - but not all - of our audience. Also, self-awareness is hard (that is, watching yourself demo and looking for bad habits that might communicate the wrong message).
So if you see something that seems questionable - do question it. A good presenter will affirm your thought or at least explain their choice for you.
How many time have you seen a demonstrator move the tool rest while the wood is spinning? And immediately say, "This is not safe, you should not do it." I bet I've heard and seen it over a hundred times. (And done it maybe twice)
When we get experienced, we do some things that are not entirely safe, and get away with them. Sometimes it's because we are experienced and sometimes it's just luck.
All of the above responses provide wise advice.
Well, my #1 advice would be to stand out of the line of fire, at ALL times. #2 would be to check your lathe speed before you turn it on. I think most lathes now have "soft" starts, which only gets you so far. A member of our club likes to talk about the first AAW Symposium in Davis, CA and he saw David Ellsworth forget to check his speed and the piece went through a wall.... I have torn pieces off the lathe by trying to take too much off in one pass, more than once. Once, while doing a demo, I went past the center of a bowl I was hollowing out with a scraper and the scraper came around and bit my thumb.... From Will Rogers, some thing like "Good judgement comes from experience. Experience comes from, well, bad judgement."
The number of serious injuries in turning requiring a trip to the ER are likely minuscule. But it might take only one to lose an eye or something even more serious.
And this attitude AAW'ers are somehow better than Youtuber's is ridiculous. AAW has any number of videos that would result in fines if OSHA safety standards were applied. How many here have ever run a shop with employees that were subject to unannounced state safety inspections with fines for safety violations?
That's for sure. Just the smallest things like turning bowls from square blanks. Totally stupid to go from square to round on the lathe because it creates a pinch point problem. Ask a "pro" why they do it, I've been told because sawing it round takes too much time, really??
Try playing "Where's Waldo" next time you watch a turning demo video. You aren't paying attention if you can't find a couple.
not sure what production bowl turners you have talked to. The ones I know bandsaw their blanks round.
And then core bowls out of the round blank. Cuts the gouge time way down.
On a small piece of wood like 3x3 going from square to round is faster
Spindle turners do almost always go from square to round.
With a single tank? Yikes! We used double tanks, but some I knew would carry two on the back and strap on one or two more spares.
That place must have plenty of natural light. I’ve never seen a cave diver without a light in the hand.
Here’s a possible interesting diving tidbit. Almost every diver, open water or otherwise, carries a knife strapped to he leg or arm. Some carry huge knives, WAY too big IMO. I carried a knife with a double-edged 3” blade in a sheath on a carrier on my wrist. The ONLY time I ever used it was when diving in Dale Hollow lake in TN at night in the winter. A guy at the boat dock begged us to go down and look for his tackle box sunk in a storm a few days before. The boat sunk too but they were able to pull it out. We found the tackle box.
But NEVER go diving under a dock without a knife. In just a few minutes, both Carl and I were so tangled in a web of criss-crossed fishing line that we’d still be there without knives!
Another hint for icey water diving with a wet suit instead of an insulated dry suit - I always took a Coleman cooler with plastic milk jugs full of hot/warm water. Before entering the water, I poured the warm water into the wet suit where it displaced the air. Then when I hit the water, the freezing water couldn’t enter the suit and displace the air since the air was already displaced by warm water! SO much more comfortable. Those who like diving in ice water might try that. (That would be almost everyone reading, right?)
Face shields are a pet peeve for me. A chunk of wood flying off the lathe could easily have the force of a baseball thrown by a pitcher. Would you wear that face shield behind the plate? Follow Reed's advice, "stay out of the line of fire". The trick is figuring just where that is! (Walls and machines can change the trajectory of that flying chunk just like the foul-tip coming off a bat.) My advice is to carefully inspect each piece of wood before you mount it on the lathe. With experience and sometimes folly, some will choose to turn what others would toss into the burn pile.
I find it quite comfortable with the drysuit and dry gloves. Only thing that gets cold water on it is my cheeks. 🥸
Agreed! I tend to either wear my chainsaw hardhat with screen or a Versa Flo M-307 Helmet. Protect the noggin and lungs.
What, no insulated full face/head hood??
I think I mentioned that even with a drysuit over a full insulated suit we would still get quite chilly even in 74-deg water, because of the long decompression stops - some dives took two or three stops and we sometimes had to stage full tanks at the stop areas to have enough air. Prob be dead if someone found the tanks and stole them. Learned to sleep underwater and keep breathing.
The worst open water dive I ever did was in the Cayman Islands - I must not have tightened my weight belt properly and lost it backing off the boat. I found two heavy rocks on the bottom 60’ down and did the entire dive by carrying one in each hand. Fortunately, I didn’t take the underwater video camera system on that dive. Dived with sharks (ever scratch a shark on the back?), we once had a dozen 5’ long barracuda circling. Night diving in the tropics brings out the dangerous jellyfish and moray eels. Had months of pain from a close encounter while photographing a sting ray in the Keys, and a gigantic grouper approached and tried to snack on my fingers. Not too much blood (teeth are sharp but small.) A fascinating thing I saw was a duck diving 50’ deep in King’s Bay Spring looking for supper. Who’d a thunk it?
Good clean fun! (And way further off topic!)
Ok, back on topic: woodturners, wear a respirator when sanding, a face shield when turning bowls and such, safety glasses otherwise. (The National Lab where I worked had a Wise Owl photo gallery down the hallway leading to medical - pictures were of people wearing safety glasses with one or both lenses shattered.) Don’t crosscut round or otherwise unsupported wood on a bandsaw. Don’t super glue your fingers together and don’t get your hand stuck to something unmoveable when the debonder is just out of reach. (In an emergency, a scalpel with a #11 blade can cut through the superglue layer without removing any skin if careful - I promise.) Use clamps and vise at the drill press, keep hands away from the edges of belt/disk sanders and don’t drill through a piece of wood held with the fingers. DAMHIKT
Not a pro, but I do try to be safe.
1. Only at a very low RPM, but it does make it easier to put pressure on the blank from the bottom so it threads on properly. I would not do this at a high RPM.
2. NEVER. EVER. Now, finger swung underneath, so that its not resting on the toolrest, sometimes, to help stabilize the blank or something like that. But only when the blank is smooth and round.
3. Never tried this... I usually remove the tool rest entirely when I sand (and I always sand by hand), so its never there as a temptation even.
4. If you have sufficiently sharp tools, and are not cutting past the end of the wing, meaning you have a full, sharp edge in the wood, and you are using the bevel properly (so you can't catch), then a small tenon will work as long as it is secure. The key, is tool sharpness. When you use very very sharp tools, the amount of force involved when taking a cut, even a large one, is relatively small...because the edge is cutting and removing wood. If you feel there is too much force involved, then your edge has dulled...so go resharpen. This also may depend on the type of wood, and whether it is green or dry. With green wood, you can often take huge cuts without much issue, especially on softer woods. On harder woods, and with dry woods, you might not be able to take a full elseworth gouge from tip to the back of the wing....unless it is just exceptionally sharp, but if you feel like its going to rip the bowl out of the blank, then take a smaller cut. In any case...I think this is more to do with tool sharpness. A very sharp tool will move through the wood like butter, and so long as you are properly using the bevel to support the tool, then you will cut and not catch or grab.
5. I use a face shield. I am a bit paranoid about this. I have worn glasses most of my life, and my most recent few pairs have been extremely expensive (IIRC, the last pair of glasses, which correct my vision pretty much perfectly, and give me extremely clear vision, was $1200), and I am always afraid of damaging them. I have had some bowls blow up on me in the past as well, and if it hadn't been for the face shield, sometimes these pieces can go flying at pretty high speed. I tried my hand at inside-out Christmas ornaments a couple of years ago, and I had a number of those fly apart as well (poor quality double sided tape!) I have also had issues with finish or more specifically CA glue, flying off the lathe, if I turn it on before its entirely cured. I actually have a small dot of CA glue on my glasses right now...thankfully its near the top rim, and is not in the center of my vision, but I've had that in the past as well. A face shield will keep finish or CA spatter off your face. So its safe and otherwise convenient for other reasons.
Something else that should also be noted, is a respirator of some kind. Boy, the amount of times I see turners in their videos not wearing even a simple unported N95 mask, let alone a respirator, to do even a minimal job of keeping wood dust out of their lungs and nasal passages... I recently heard a story of a guy who had to stop turning entirely, because he can't breath through his nose, and when they really went looking for a reason why, they found none other than an insane amount of wood dust packed into his nasal passages and sinuses! I guess he is going to have to have surgery to clear things out, and its not a trivial surgery, since they have to get into the various sinus passages? That story kind of terrified me. I hear something similar can happen to your lungs as well. Wood dust doesn't just get broken down in your body...if it gets in there, it accumulates, and builds up... 😨
Another thing I always do, is use push sticks or something like that, when cutting things on a table saw. Or a sled. I try to always use a sled for my bandsaw, except when I'm rounding out small branches/logs when trimming off the nubs of branches and the like. I never drill with the drill press, unless whatever I am drilling is securely clamped down (well, very early on, I had a piece I was just hand holding ride right up the drill bit, in less than a second! Scared me as my hand went strait up too, but thankfully not into the bit. Ever since then, I clamp whatever I drill.)
I use at least safety glasses with the table saw, but sometimes I'll use a face shield. I try to avoid kickback as much as I can, and use the safety features of my table saw (except when using the sled, since those features are just not an option when using a sled) to try and limit how much kickback can even occur. Still, I've seen enough cases where people just, make a tiny mistake, and non-trivial sized pieces of wood can roll right up on top of the blade an go flying right back at the operator, at high speed!
I heard a saying years ago: "Safety is first and foremost a choice." It really is!
A lot of Youtubers, and Live demonstrators, have to be able to speak clearly while turning, and that, as I understand it, is nigh on impossible to do when wearing a respirator or mask.. Quite possibly they Do war respiratory protection when they are doing their regular (non-demonstration) work. I've seen several make mention of this (The fact they advise respiratory protection and why they aren't wearing it during the presentation)
Kent Weakley at www.turnawoodbowl.com narrates his videos after the fact. I like that format.
These are all things that may seem safe to them, and they get away with it. (most of the time) There's always that one time, when things don't go as expected. You're not being paranoid, just do what feels safe to you. These mostly sound like timesavers, but imagine what an ER visit will do for their time efficiency. :rolleyes:
Possibly. I'm not really talking about demonstrators so much, and some of them I actually have seen wear N95 masks or even respirators while they actually turn, and they take it off when they stop to talk. I was more thinking of those who seem to film and share just about everything they turn on YT... There are many, who I never see wear as mask. A lot of them also do voiceover after the fact, so they aren't actually speaking live, and they aren't wearing a mask in the videos. It just concerns me...that I see that so often? I've suffered really badly due to not wearing a mask when I started in 2020. It wasn't really my choice, though...I started turning right as the pandemic was starting, and ALL respirators and N95 masks by the time I really got going (late March, IIRC) were reserved for front liners. I wanted to get at least an N95 mask, but was unable to order them on Amazon (even though they were listed, Amazon wouldn't sell to the average customer) and the local hardware stores and such did not have any masks of any kind in stock, except the useless blue medical masks.
It was late July that year, before I was finally able to get a 3M half face mask with some particulate filters. By that point, I was already suffering from the dust exposure. I turned more green wood back then, so there wasn't as much dust, but there was enough that I was having problems. (It was a combination of wood dust and more significantly, CA glue fumes, which caused me some horrific problems starting in the summer, and I didn't discover that CA glue fumes were part of it until mid September...once I did, I ended up buying a Sundstrom SR500/580 PAPR system for heavier turning, and started using the pink/mustard organic vapor filters for the 3M half face mask.) I have eliminated exposure to CA for the most part, and only use GluBoost now (which has very low odor and seems to release compounds far less noxious and toxic to me than other brands. So most of my issues have been resolved. Wood dust exposure still causes problems, but I'm pretty good about avoiding it now. It took me a good long while...close to a year...to really fully recover from what it all did to me. For a lot of that time, I couldn't breathe through my nose at all, my sinuses were so stuffed on a perpetual basis.
When I hear many of the presenters I watch talk, I can hear how nasal it sounds as well. So, I know that some of them, are not protecting themselves, and sadly are probably suffering as a result. Its probably the thing that surprises me most. Even if someone is talking live, I think there are ways that they could both wear a respirator and still be heard...for example, one of those small microphones that hook over your ear, and have an arm that extends a small mic out towards your mouth? You could fit one of those inside a 3M half face mask pretty readily... With mine, I think there would even be enough space to keep the mic a bit away from your mouth so you aren't munching on it.
Try to get some ParFix 3408 thin CA. It is slow to set and doesn't create the eye-searing fumes of standard CA. Also, doesn't create heat when in contact with moisture.
Sounds similar to GluBoost. I tend to have a SEVERE reaction to Stick Fast, in particular, and Starbond. Both are pretty nasty. I have a bad reaction to Mercury and Tightbond, and there is another brand the local woodcraft carries that has caused problems as well.
GluBoost, is low odor and all that, and I've been exposed to it accidentally a few times, and hardly had any reaction at all. Its really strictly a finish, though, and its explicitly intended to be used with their GluDry accelerator, and I wonder if somehow, they were able to eliminate the noxious toxicity, by pairing the glue and the accelerator in some way? The glue doesn't really cure well without the accelerator (eventually it will, but it can take a real long time.) So I wonder if this stuff is very similar or the same as the ParFix.
I've largely eliminated CA from my work though, and the only time I use any, is as a pen finish. I used to use it to fill cracks in wood, but unless its really the only option, I have even switched to using wood fillers for that instead (never quite liked the shiny clear look of CA, next to the entirely different fibers of the wood.)
Standing out of the line of fire is probably the best advice to give anybody, simple and effective .
There is another aspect to safety, complacency . I worked in the mining industry for over a decade and the most dangerous period in this industry was the tenth year. In this year some of the worst injuries occurred. It didn't matter what geographical area you worked in . I worked in 2 or 3 continents and the stats remained the same.
Injury or accidents are caused they don't just happen.
And if there's any question about the soundness of the wood, keep the speed down. I turn pretty slowly anyway. The kinetic energy of a spinning piece increases exponentially with an increase in RPM.
Loose focus it invites disaster.
A freind who is excellent on the bandsaw was cutting a whole bunch of pen blanks for his nephew.
Repetitious, monotonous, the last one he cut that day he passed the former ent of his thumb past the blade.
This is not possible with all tools and all turnings
Easy with open forms using a gouge.
Spindles, spheres, ornaments, and many hollow forms I get in the line of fire.
Some of the no learning required carbide tools seem to require the user to stand in the line of fire while roughing.
Some of those tools are offered with chip deflectors.
Somehow it always seems to happen on the last one of the day.
The "former ent" is an interesting image.🙂
I was intrigued by the "former ent" image too, even if a typo. For a second it made me think of wood as pieces of former Ents in LOTR!.
I have a mantra I repeat to myself as I start and finish EVERY cut on the bandsaw: "Where would my fingers go if..."
Some "if"s:
- "if the wood broke or disappeared",
- "If something slipped",
- "if an unsupported cut caused the wood to suddenly move or jam"
- "if something got caught, say on the back edge a misaligned blade insert in the table and I was tempted to use a little force just this once",
- "if I got in a hurry or sloppy at the end of the cut"
- "if I told myself I could handle this overly heavy chunk of wood or extra long board without enlisting help, just this once"
- "if I knew the blade was getting dull but was tempted to just use more force instead of stopping to change or sharpen it"
- "if a push stick broke",
- "if I didn't clear something on the floor that might distract me if I stepped on it",
- "if the smoke detector, phone, driveway sensor, whatever were to made a sound",
- "if startled by a sudden noise outside, crash, tree or something falling, loud thunder, someone knocking or entering the shop",
- "if concerned/worried about something, friend or family member, feeling sick, exhausted",
- "if feeling pressure to hurry",
- etc.
I like to think that just repeating "where would my fingers go if..." mentally with EVERY cut helps me think of things and perhaps keep me from getting complacent, know when to just stop. As I discussed in the video, it would be hard to do any wood turning without hands or fingers. And it's such a hassle to go to the ER. And clean up blood later.
I also don't play music or listen to the radio when working at the bandsaw. When teaching my little bandsaw classs with 4-5 people in the shop I have to force myself to focus. For every cut. And everyone sits - no moving around! I'm so mean.
Same for the table saw, circular saw, chainsaw, other things that eat flesh.
I use hollowers exclusively for HF with these it's not so difficult to get out of the way. Externally is another issue, I turn left and right hand so moving out of the line of fire using my left hand works for me. But it's not for everyone.
I’m out of the line of fire hollowing
It’s shaping the outside where I’m in the line if fire part of the time
