Question on fountain pen nibs
Alameda, CA
I recently purchased a couple of Chinese-made fountain pens (https://www.amazon.com/dp/B0C1SQXWVZ). They have a fine, 0.38mm nib, which is very smooth to write with. However, the pens themselves leave a lot to be desired. They are made from cheap plastic, look cheap, and feel cheap. The pen is much too light for my big hands. These pens are refillable (not cartridge-based) and have an ink reservoir that is integral to the nib body (see below).
So the question is, are these nibs interchangeable with those that come in kits for pen turning? I would like to have pen bodies from a more dense wood (like wenge, cocobolo, goncalo alves), and would like to use these nibs instead of those supplied with a kit.
Or would I be better off drilling and tapping my own adapter insert?
Thanks, perfect! If I ever get seriously into pen turning, that site looks like a great resource.
Looks like I may need a 12mm x 1.0 tap, which I think I probably have. Or maybe not - I'll take the pen to the hardware store to get the correct thread size.
It's been a good 20 years since I made a pen, but are you certain the reservoir doesn't pull away from the nib for refilling? Looks like it could. For $10, you could try separating them, maybe they'll pop apart. If it breaks, such is life... at least it wasn't $50.
The translucent reservoir part does come out of the nib housing for refilling. It has a syringe-like screw plunger that pulls ink into the reservoir when rotated.
It has been my experience that the threads on the Chinese pens are non-standard. Good luck getting the right tap!
I guess I'll find out when I go to the hardware store. Being Chinese made, I'm sure it's metric. If worst comes to worse, I can always make a silicone mold and cast a female part from resin.
