quick change buffing wheels
Chicago
Hi all,
Has anyone tried to make a quick-change system for swapping out buffing wheels? If so, can you point me in the right direction?
I'm thinking it might work to have a Jacobs Chuck holding a magnetic hex bit holder, and each buffing wheel has a hex shank (from a cheap drill bit set). But, there is a bit of slop between my shanks and the holder - not sure how much of a problem that could create...
Thanks for any advice you can offer,
Lee
I just use the Don Pencil extension bar that threads on the lathe spindle and has a thread for the buffing wheels. All of wheels have mandrels so it's just a matter of putting the lathe in reverse, pull of the old wheel, put lathe in forward and the new one is on is seconds.
I use the same set-up, it's quick and easy.
Ditto - Don Pencil Extension Bar
Ditto - Don Pencil Extension Bar is a great system, easy and quick.
I store mine in a drawer right behind the lathe so it's right there all the time. Convenience adds to it's ease of use.
Here is my system. You can change out the wheels in a few seconds.
Marvin.......That's terrific, and very ingenious. It's an inspiration to see others use their creative instincts, rather than to just buy stuff.
It's not really apparent from the photos, but how did you attach your buffing arbor to the spindle?
The wood is threaded to fit the headstock. This is an older version, on version 2, I turned the shaft so that I could force a piece of PVC pipe on o the wood. The PVC pipe provides a lot more strength to the piece of maple.
It is not totally my idea, I saw a similar set up used on a motor shaft, so I made some like it to fit the threads on my lathes. I have also them made for disc sanders and various specialty mandrels. Saves a bundle on tooling costs.
