  • Congratulations to Dave Landers for "Simple Goblet" being selected as Turning of the Week for June 17, 2024 (click here for details)
Raptor angle setting tools
Status
Not open for further replies.
Marshfield, MO
I am looking for some angle setting tools. I haven't been able to purchase a CBN wheel yet and don't want my angles on my gouges getting out of whack. Seems a little expensive for 10 bucks a piece on Woodcrafts site, so was hoping someone had some they would like to part with for a decent price.
Montgomery, TX
www.gulfcoastwoodturners.org
Toss the Raptor jigs far into the darkness of the night and go with 1' PVC pipe to set the V-arm extension distance. See attached photos. Cut PVC pipe to length (trial and error) that sets the V-arm to the proper distance for required grind. Works great with CBN (or similar) grinding wheels because they never change diameter. With a constant diameter grinding wheel and extension of V-arm set by PVC pipe, two of three variables required to reproduce your favorite grind are set. The only remaining variable is the angle of the leg on the Oneway (or equal) vari-grind jig. I have my vari-grind leg more/less permanently set. So, when I want to change grind, all I have to do is pull out the proper PVC pipe, set the V-arm and grind away. - John
PS - Not the originator of this idea. Picked it up on some woodturning forum/website. - J
Marshfield, MO
that would be great if I had CBN wheels, as I um unable to afford them as of yet, I am stuck with the regular wheels that will lose it surface and require me to be able to set it back up on the correct angle from time to time
New City, NY
The most important angle on a gouge is where the nose of the gouge meets the grinding wheel with the flute facing up. That must always be consistent . Once this angle is established, you can always place the gouge against the grinding wheel and make adjustments and use aids as the others described above without having to purchase angle setting jigs.
I have made standard angles by cutting 1/2” dowels about 6” long on the table/chop saw. I have cut every angle that I can possibly use for pennies.(free if you turn your own dowels).
I place the dowel(just like I would a gouge) into my varigrind(at a preset swing) or Ellsworth jig both at a consistent 2 inch depth so that the dowel is tangentially touching the grinding wheel at around 1-2 o’clock (never greater than 3). Then I adjust the slide last.
Optionally, You can purchase a male and female threaded plastic conduit connectors in HD or Loews for about $2. These can be used with a pvc stop block to fine tune the slide distance as the stone wheels wear.
Status
