  • Congratulations to Ted Pelfrey for "Cherry Burl" being selected as Turning of the Week for September 1, 2025 (click here for details)
Really BIG Funnel
Traverse City, MI
I've recently scored some nice turning wood, and gotten into some bigger size pieces lately. I cut a 28" diameter log down the center. ONe side is pretty rotten, but the other looked like a nice huge bowl blank. I decided it was a bit too big to get on the lathe, and since I finally set up my alaskan mill, I cut a big slice off the face of it. I thought it might make a nice platter for on a wall or a centerpiece.
My wife is out of town, but coming back home this afternoon. I wanted to to turn this and get it done with enough time to walk the dog and clean up a few things. I made a simple compass to mark out 24" diameter. I marked 25" as well, since that's about the limit of my lathe. I chainsawed that 2nd line. (only one small corner had to be sanded away to spin it. In the compass point, I drilled a shallow hole the size of my Elio drive. A 3" disk of wet beech is pretty darn heavy, and having that hole to "hang" it on, while I bring up the tailstock, is really handy.
I trued up the face and diameter of it. It was still unbalanced, so I used my curved inside bowl rest to reach around the true up a good part of the other face as well. I cut in a tenon for my chuck. (Hindsight: Had I removed all the wood around it, instead of just making a notch, I might not have screwed up.) I shaped the bottom side, and because of the large diameter, I left some wood for a larger diameter foot. I fliped it around, keeping the tailstock in place for extra security.
I made the rim thickness about 3/16" and found that at the edge of the bowl part, my calipers were about maxed out. I had to eyeball the angle and depth of the side of it. I set my long tool rest parallel to the face of the rim and used a couple long rulers to measure for depth, one across the face of the btoom "foot" I had left, and the other to measure the distance. My calculations were all good, but being a hidden mortised tenon, I didn't see the chuck jaws. My ruler laying across them made them even more invisible. Needless to say, I was really surprised (and disappointed) to see them.
A couple hours and a nice piece of wood, wasted!
Could be a nice mirror frame or
One ring of a future sculpture honoring the 2028 Olympics
Be a great opportunity to explore ring turning. Screw it to plywood disc turn a profile on the out ring
Leaf outline, spirit bear, snow person
The slice on the bandsaw to get dozens of the objects.
A big ring has countless uses
There are countless ways to measure wall thicknesses and bottom thicknesses so that no one should turn through the bottom anymore. Search back issues of the American Woodturner and Google. Here is as fine example on Google
I've seen Simon Begg's ring turning and the really cool stuff he makes, but this is only 3/16" thick.
It might make some kind of frame for a mirror or something. Maybe a canvas for carving/texturing practice. It might end up on the shop wall to remind me to slow down and not rush needlessly; inviting mistakes. (wife texted she'll be home about 3 hours later than expected)
Condolences. Thank you for sharing your process and after action analysis. Others have made recovery suggestions. I took a class from Michael Hosaluk and he brought a small plate / platter that he had cut up and suggested that the play around rearranging the pieces. Which brings me to my suggestion. Perhaps cutting it in to pieces and then reassembling them would result in something you would like.
I helped a friend figure out how to hold and turn a thin frame for an embroidery. It was a challenge. Supported on the lathe with a plywood disk.
A mirror frame is a nice idea. The turned front doesn't have to be thick if it's wide enough to hide the support behind. The wood on Darryl's does look worth repurposing.
Make a jam chuck out of a piece of plywood and turn the damaged bottom out? Then turn an insert to fill the donut hole.
A visiting turner did that here on a walnut lidded box. Turned an Ebony insert for the bottom and for a consistent theme, an Ebony cabochon on the lid. Looked great.
Darryl, I figured this one out a long time ago, and still use it today. Well, not today, I am doing boxes.... I did form a piece of plywood on my Vicmark 240 since the head tapers back a little and hot melt glued it to the headstock.
View: https://www.youtube.com/watch?v=0Ov5m50NXJ8
I understand all that, but due to my rushing and the giant size, I just forgot my chuck jaws were recessed in.
