I have a Thompson 1/2" bowl gouge with a U flute. I don't like it much. All my other gouges cut better. Can I regrind this U flute into a detail spindle gouge?
Kent-I have the same issue with my 5/8" Thompson Lyle Jameison gouge. I loved it when I first got it a few years ago with its original grind; it was my 1st big gouge and helped me learn all the basic cuts very well. It was and is advertised as being parabolic, but the wings have slightly less recurve compared alongside my Crown PM Ellsworth gouges.
Tomislav and Richard...When sanding, I can some times start at 120, and some times I have to start at 100 grit, but most of the time I can avoid the 80 grit. These guys start sanding at 180. This takes me back to Mike and Stuart doing their 2 ways to turn a bowl, which are almost identical to me, and Mike commented that he would spend less time sanding than Stuart because Stuart started at a higher grit where Mike started at 80. Not sure about that one, in part because some times 80 grit scratches seem to be deeper than the tear out....
