Removing anchorseal from wood
Claxton, Georgia
I have looked and couldnt find it. I know I have seen something on this before. I am trying to remove some anchorseal from a piece of wood that I want to use as a scuptural piece. Any help would be appreciated
Rather simple, Stacey.
1. Heat gun or hot hair dryer to melt and wipe off as much as possible with rags or paper towels.
2. Solvent such as Mineral Spirits, alcohol, or Naptha (better) to remove the rest.
3. If you're working with a piece of burl with a spikey surface, a powerwasher after the heat step does very well.
m
I believe that some of the Anchorseal that one puts on a chunk of wood is absorbed down into the wood pores. Very hard to get this out and the Anchorseal may change the color of the wood some or keep finish from attaching properly. I am thinking end grain here. Just a thought.
Hugh
Hugh
Hugh,
It's a common misinformation that wax will penetrate wood. Those Johnson people made billions selling that "Good-for-the-wood-'cause-it's-wax" slogan which is pure, um, "wax." ;)
General rule is that wax molecules are too large to penetrate wood pores, even on the endgrain, and even if dissolved in a thinner that will penetrate. Anchorseal is a water/paraffin emulsion and will not penetrate, even if heated to boiling. This is one of the reasons why wax is such a poor "finish" for wood. It will, however, do a good job of forming a temporary film to retard moisture loss.
Thanks Mark. I will give that a try. I did a little mineral spirits and lacquer thinner last night in a small area but wasn't too sure if it was working. I will try it again along with the heat on a larger area along with using something more durable than a papertowel to rub the thinner.
stacey
stacey
Hot solvent is NOT good and using a heat source along with something like lacquer thinner is asking for visits a) from the Fire Department and b) to the nearest burn ward. Please don't go there!
You can scrape much of the coating off, melt most of the rest so it runs and drips off, and then only use the solvent to remove the thin residue that's left. Lacquer thinner is not, however, a good wax solvent for some reason, so stick with the three I mentioned. MS will take the longest to dry, and alcohol is slower as a solvent.
Sorry for the missunderstanding.I don't plan on heating the MS soaked piece of wood. Thanks again for the ideas I will give them a try. Now to get some Naptha.
Might want to try the hair dryer before the heat gun. The latter can easily ignite the wax and the wood. The hair dryer on high should melt the wax easily enough.
Stacey,
If it's really Anchorseal, I checked with UC Coatings and they said it can be completely removed with hot soapy water. That translates to 5-minutes-of-fun-for-a-fin down at the car wash and you, your car, and your wood're done and clean. :D
Mark Mandell said:
Stacey,
I second that -- just recently I coated the ends of around 3 dozen blanks I'd just slabbed and before getting them into storage a shower hit and I watched the Anchorseal drip off the wood onto the lawn.
Stoppy
Hot Enough Outside ??
Geez,
If you cut your blank slightly oversize and coat the ends. When you are ready to turn --- trim off the end.
Anchorseal, the brand name and the generics, do not penetrate. If you have a small crack, split etc or two --- you want to cut them off anyway.
So why worry about heat guns, MS, trips to the car wash?
John :)
Thanks everyone. It looks I will be looking into going to the car wash. I will not be turning this piece so I can't just turn away the wax. Thanks again for the help. I will post my results when I get the wax off.
Stacey
I was wondering about to get it off the rough edges of some rough edged burl wood I was doing,so I called the place where I bought it and was told to just use a stiff bristle brush and any kind of liquid detergent.So that is what I did and it took it all off in no time,then I rinsed it in clear hot water and the piece finished up great.They also stated NOT to use any chemicals.
