Removing Carnauba Wax
Baltimore, MD
loujacobswoodturning.com
I have a piece that I applied carnauba wax to. The finish came out beautifully with a hard, high gloss shine, but I’d like to remove it. It is too glossy and plastic looking for this piece. I’d like to put on an oil finish instead. Is there a solvent that anyone has experience with that would save me from having to turn off the finish? It is on hard (sugar) maple, so is not imbedded in the grain so much as on the surface of the wood.
Mineral spirits will take it off. When I get a piece that is too glossy I scrub it with 4/0 steel wool and which makes it very satin. If I want it shinier then I rub Johnson's paste wax on it.
I believe turpentine will also do the trick. That is the solvent for Kiwi neutral shoe polish, which is carnuba wax.... Hmm, spell check doesn't know what carnuba is... It is also the solvent in Butcher's Wax, a product used on bowling lanes, and carnuba based.
Thanks John! I’ll give that a shot. It is also lighter than I’d like it to be, and I think walnut oil will give it a bit more color.
Also, Danish Oil comes in several shades of walnut color......:D
I have turpentine in the shop, what an awful smell... I use it as little as possible.
Hmm, I kind of like turpentine smell. I thought it is derived from tree sap, but not positive on that. Better than mineral spirits or lacquer thinner...
I think most solvents will dissolve/wash it off lacquer thinner, acetone, toulene and espically MEK. acetone is said to be the fastest evaporatin.. ofcourse they are very flammable. like the flash point of MEK is 24 degrees F
