Replacement banjo for Nova XP DVR?
Cullowhee, NC
My 14 year old Nova XP DVR has been replaced with a new lathe that is much larger with a swing over the bed of 24" compared to the 16" of my Nova. I still like the Nova and keep it around because it has a longer bed with the extension than my new lathe is capable.
My experience with the new lathe has given me a new appreciation of how nice it is with a smooth moving banjo/tool rest. I saw John Jordan at our turning club and one of the things he recommended is to clean the ways and bottom of the banjo and tailstock with lubricant daily. This has helped, but it still isn't as nice and smooth as I had hoped.
I took a week long course from Ernie Conover and just recently saw him with a new OneWay banjo on his Powermatic. It got me thinking that perhaps I could find a replacement for my Nova banjo that would fit and be the appropriate size.
Has anyone replaced their banjo on a Nova XP DVR?
If so, did it make an improvement for you and which banjo did you find to replace the original equipment?
I would appreciate any help with this issue.
Thank you.
My two oldest lathes the DVR3000 and my Powermatic 3520b (over 20+ years old) still use the same banjo and I've never had a problem with either and that can be said for the others in the shop. I have never wanted them to be super easy to move as when I hit that arm to tighten it I want it to be non-moveble without hitting it with a hammer. There's crap that you can put on the bed and bottom of the banjo that will allow you to push them right off the bed. I used a Boeshield product long ago that they don't make anymore and now I use DuPont non-stick dry-film lubricant every 4 or 5 months when and if needed. Keeps them working just like I like them.
This Oneway 16" banjo might work for you. I replaced the stock banjo on my old General 260-20 with a Oneway and it was a huge upgrade. I kept it when I sold that lathe and still use it on my Oneway 2436. Two banjos can be very useful at times.
Thank you guys.
The real reason I want a new banjo is that the Nova XP banjo's handles for locking the banjo movement and the tool rest tightening lever are so close to each other that I need to constantly adjust them so that they don't interfere with each other. I purchased a new post/lever knob for the tool rest post that helped, but it still gets in the way.
I never have this kind of problem with my new lathe, but I understand that the larger lathe has more room to work with to separate them.
I will check out the Oneway 16" one. Thanks Kevin.
I replaced my Galaxi banjo with the Oneway several years ago, and I've been very happy. I thought I might have clearance issues for some tasks, but the Robust low profile and J rests have not been a problem. Talk to Oneway.
Great news. Thank you, Mike.
These two posts by Kevin and Mike give me hope.
I've submitted a question to Oneway and expect an answer soon. If positive, I'll be ordering one.
Thanks
Thank you guys.
Sounds like the banjo lock is misadjusted. You can adjust the linkage so the lever swings below the level of the post lock lever and lock tight before it reaches very close to the bottom travel.
Thanks Gary, I actually saw a PDF on the Teknatool (Nova) site on how to make that adjustment. I'll give it a try before making the purchase of a new one.
