replacement papr helmet
Huntington, VT
I have an old 3M Airmate 3 system (yellow hardhat). It's getting harder to find parts, in particular replacement visors and beard seals for the helmet. I have several blower units and filters are available so I would like to replace the helmet only. I figure I can adapt my hose to a new headpiece. Any recommendations for a helmet substitute, or a source for parts? I know I will have to bite the bullet and get a new system eventually but would like to put it off.
I bet the 3m versaflo head gear would work, though you might need to jerryrig the connection. There's a choice of helmets and I believe it's the 201 that's lower priced and adequate for turning. Probably available on fleabay.
I bet the 3mversaflo head gear would work, though you might need to jerryrig the connection. There's a choice of helmets and I believe it's the 201 that's lower priced and adequate for turning. Probably available on fleabay.
That's probably where I'll wind up when I use up the Airmate consumables. For anyone thinking about a powered air purifying respirator, you can put together a Versaflow system from components on Ebay for <$800.
