Segment thickness
Springdale, Arkansas
All of the segmented turnings that I've seen use segments that are close to 3/4 inch or thinner in thickness. I'm thinking about a project where my thickness would be 1-1/2" thick or a little more. This would cut down on the number of rings I need. Is there any downside to using thicker segments?
I have done a couple large bowls with 1 1/2" wood and they came out reasonable looking
If only I had made the workbench a foot longer.
My normal method of gluing rings didn't work so well. This ring is 15" in diameter and the tape didn't hold the blocks secure enough to fold up in my test run. Did something a little different and glued half rings.
I'm way off in the weeds with this project. It's similar to a Modeline of California pendant lamp and will involve some eccentric turning along with veneer work.
