Sharpening question
www.mikecunninghamwoodturner.com
A member of my club has a question, perhaps someone here as an answer.
He has Delta Sharpening Center with a white 200 grit vertical high speed stone and a wet 800 grit horizontal slow speed wheel.
He wonders if a commercially made jig for sharpening gouges is available or if one can be adapted for use with the wet horizontal wheel. Or, has anyone built such a jig and would share the info.
I'm a Tormek guy and while I've seen the Delta set up, have no knowledge of it's functionality, etc.
Thanks in advance!
Mike
Cape Atlantic Woodturners
http://www.capeatlanticwoodturners.org/
Mike,
If you're talking about turning gouges, I'd rather doubt you're going to get much on this question. I have a horizontal (Combo vertical) grinder, but I'd never use it for turning tools. It's way too slow and not worth the set-up/clean-up mess. For carving gouges and flat iron they're great because you can eliniinate the hollow grind. IMO, useless for turning.
Mark
