Sharpening System $100 SOLD
Status
Not open for further replies.
Dennis J Gooding
Grants Pass, Oregon
Consists of a Rikon motor with 80 and 300 grit wheels mounted on a small sheet of plywood together with a OnewayWolverine sharpening system and ready to use. Small keys are provided to set the nose angle of the gouges to 30, 40, or. 60 degrees. Keys for other angles are easily made. In addition, the Oneway gouge jig has beed modified to produce the so-called 40/40 grind as well as the more common ones.
SOLD
Status
