Until recently I had been using a lacquer based sealer with very few issues. Just started using a 1 # cut of shellac made with flakes. I put on the first coat followed shortly by a second coat. The surface after sealing is very rough. After about fifteen minutes I sand with 320, the surface is better but not nearly as smooth as before sealing. The sandpaper clogs very quickly. Am I not waiting long enough to sand back? Other issue is the surface after sealing looks terrible. I have read threads that say my sanding is not good enough before sealing. I have used naphtha to try to find where my sanding before sealing was deficient but I don’t see anything wrong. On both walnut and cherry that I did not seal I see no difference between sealed and unsealed finishes. Do some woods not need a sealer? Frustrating!
