• It's time to cast your vote in the May 2025 Turning Challenge. (click here for details)
Shop Made Wolverine Jig
I recently copied a photo of a wooden, shop-made, wolverine type grinding jig. I'm working on a workshop for our members and would like to offer this as one of the available resources for those who like to make everything.
Capt. Eddie Castelin
The Bayou Woodturners
www.bayouwoodturners.com
I for one would be extreamly interested in learning more about any and all shop-made grinding jigs :) Any chance at making this availiable to others who can't make this workshop?
--eric
Look at Darrell Feltmate's Sharpening Guide
Great site: http://www.aroundthewoods.com/
I have used Darrell's system of sharpening jigs. Easy to make. Make a 45 deg and 60 deg cradle to drill press a hole for the leg. No adjustments is GOOD. I dedicate one to each bevel and tool diameter. Have about 6 or so. Just grab the right one and go. No setup time to lose and errors to make. Use a story pole to mark the location of the slideout arm pocket relative to the wheel for each jig. This all gives me near perfect repeatability with just a couple passes across the wheel. No overheating of the tool. Little loss of metal. I added an "L" bracket to swing down on the flute to insure consistent indexing of the flute to the jig.
I have attached a picture of my variation. Here is my web page describing how and why to build one, a story board, grinder comments, and some other sharpening links: http://docs.google.com/View?docID=admp7zph558w_bcj4t5jchs7kq&revision=_latest
Looks easy enough. But, what function does the angle bracket serve?
The other thing I"ve been curious about on these shop-made jigs is how you get the length of the rod/dowel right? Trial and error?
Thanks!
Danny
Angle Bracket on Feltmate Jig
Some of the manufactured jigs have a plate or disc that secures the gouge from the top and also orients the flute consistently with the jig (Kelton, Truegrind.) Other jigs fix the gouge from the bottom with the flute pushed up against a flat surface, also orienting the flute consistently (Ellsworth.)
The Feltmate jig uses a 1/4" or sometimes a 3/16" screw eye (ground to a rough hemisphere where it contacts the flute.) While simple and effective, this can result in the flute being tilted one way or the other in some cases, and can lead to a bias to grind one side or the other a little differently than the previous time. I press the "L" bracket down on the flute as I tighten the screw eye to insure that it is always oriented the same way, and get a very repeatable grind on the gouge wings, normally one or two passes.
The length of the leg is important, not only for the resultant grind, but also in my case to have a constant arm/pocket extension for a given bevel angle for different diameter tools (1/4, 3/8. 1/2, 5/8.) I have a jig for each, or maybe share adjacent diameters in some cases. Darrel provides a drawing for this on his web site: http://www.aroundthewoods.com/imgssharp/sharpsketch.jpg
I doubt that 1/2" one way or the other on the leg matters much. it is more important that the your jigs be consistent.
It is also important that the height of the arm pocket that receives the leg be located correctly with respect to the grinding wheel. This is also shown in the sketch. It is well worth reading Darrell's entire article and reviewing all the pictures. Again the site is:
http://www.aroundthewoods.com/sharp.shtml
Hope this helps.
Jerry
Thanks!
It does help a lot, Jerry. I see what you mean about the screw eye tipping the gouge slightly; hadn't thought of that.
I'll check out Darrell's webpage, it looks like good stuff to have bookmarked.
Thanks!
If I understand this correctly, the L-bracket ensures that the gouge is held squarely in the jig.
The L-bracket contacts the gouge at the top of the flutes and ensures it doesn't tilt left or right.
"L" Bracket
Jim,
You described the purpose of the "L" bracket well.
I have created a page for our local woodturning club on this sharpening system with a drawing of the revised jig. It also includes a discussion of a "story board" to deal with the problem of the shrinkage of the grinding wheel as it wears and a grinder recommendation.
Jerry
Wolverine copy
I made a Wolverine 'copy' out of oak. It works fine in our dry climate here in Tucson AZ, untill the rainy season comes in July. The thing swells up and freezes in place as soon as the humidity rises. If I loosen the tolerances so it works in the rainy season it is sloppy when the humidity drops to 3% again. I just bought a real Wolverine and it's a pleasure to use after fighting the one I made.
"Freezing" of clamp screw
This doesn't need to be a problem.
Suggestions:
- Make sure your clearance hole is big enough and clear it of shavings with several swipes of the bit. Eg. 1/4" hole for 5/16 thread
- Wax or soap the threads
- Or use an epoxied nut or "T" nut. I have done this and the "looseness" of the screw eye in the nut works in my favor by providing flexibility for the tool to seat in the center of the flute and clamp down centered on the far side of the hole. This works so well I use only one jig sized for my largest tool.
If the threaded hole is prepared properly the shrinkage across just 1/4" is not going to be a problem. At my home in the gold country of California I vary from 6 feet of rain in the winter and very high humidity to very hot dry summers.
