Skew sizes
Front Royal, VA
I see lots of threads on skews, but I am wondering what folks think about ideal size (width) for skews - that is, as a relatively new turner and if I only have 1, what is the most versatile size? Are multiple sizes worth it? Advantages/uses?
Thanks
If I could only have one, it would be something like 1/2 - 5/8" wide. That said, I use a much larger one more frequently - 1.25 and 1.375" wide. I'd start with the smaller one.
Ultimately the answer is yes, multiple sizes are needed. That said, a lot comes down to what you are turning. I prefer the larger ones for roughing, and I generally don't use a Spindle Roughing Gouge, so the skew picks up that work. There are some places where I just can't get the larger skew into, so having the smaller one is handy.
Now, I'm ready for seeing 3 or 4 other answers in the next 2 posts!
My most used ones are 1 to 1 1/4 inch wide. I do have a couple that are smaller, but only use them for things like adjusting the rim on a threaded box so the grain lines up. Yes, you can go too big. I think I have one that is 1 1/2 inches wide, and it does have a straight edge/bevel on it. I do prefer the slightly swept back designs. Most of the "production" turners use a straight across grind.
Depends wholly on what you are turning.
12" candlesticks - 3/4 - 1"
3 foot table legs - 1.5" +
Small box finials 1/4" - 1"
For learning and some of everything, 3/4-1"
If you use them a lot, multi sizes are good.
As with most turning tools, the better you can use it, the least critical the size. Borrow one, Play with it, decide when and on what you'll use it.
Many great YouTubes. Check out Allan Lacer and Allan Batty.
All sizes are guesstimates based on IMHO.
I agree. Also,
Larger diameter spindle: a wider skew can be helpful, especially for planng cuts.
Curved instead of straight cutting edges are easier for coves for some.
Small diameters: narrow skews are fine, better clearance for tight spots, easier for fine detail.
Small skews made from round shafts can be a lot sturdier than when made from flat shafts. (of course)
I agree. Also,
That makes perfect sense - but if you could only have one, what would it be?
I know that many turners agree with you about using the skew for roughing ... why? I don't understand that concept. Supposedly the skew should be "scary" sharp ... time spent sharpening, honing/stropping, etc. Why beat the hell out of the edge by roughing out a turning square? Use the SRG - it's faster IMO, and when done roughing to a cylinder it only take a few seconds to put it down and then pick up the skew. Just my 2¢.
Waiting for the rebuttals. ☺️
Thanks
I can just tell you what I use
For finials and other small spindles I use a 1/2” rolled edge skew and a 1/4” round skew homemade from a HSS round bar.
These just feel more comfortable to me on small turnings
I like the 1/2 skew for beads in the 1/2” range. I like the 1/4” skew for beads less than 3/16.
For bigger spindles I use a 1” skew.
I’ve seen Lacer turn a top about the side of a pinhead with his big skew.
Difficult to answer. Still depends on the skewing being done and the size and type of things you want to turn.
For thin spindles, like these, I use a 1/2" skew along with a 3/8" spindle gouge
For miniatures and delicate finials, I use a 1/4" or smaller, maybe along with a 1/4" or smaller spindle gouge.
For things like gardening handles, I might use a 1" to 1-1/2":
For the handles of finger tops, I use spindle gouge or small skew. A gouge or 1/2" skew for straight facing cuts on the ends.
The biggest thing is I occasionally don't even know what skew I'll like for a new project until I experiment - can depend on the wood as well as diameter. I experiment as I go, make some cuts with one, switch to another, etc. For example, I find that thin spindles with certain specific blanks of osage orange will tear out splinters along the grain unless I use a skew with a larger included angle.
If starting out without a lot of skew experience, I'd recommend what I hand to students with no lathe experience:
  • First, a 1-1/4" skew with a curved edge and a fairly large included angle (45-60-deg). Practice a lot with that.
  • Then after some experience, give them a 1" then a 3/4" skew with a smaller included angle. Good for lots of things including drumsticks.
  • When we advance to the trickier thin spindles (hairsticks, wands, conductor's batons, drop spindles for making yarn), a 3/4" skew then 1/2"
  • When they want to do finials/ornaments it's usually a combo of 3/8" spindle gouge
However, what's I think is far better is visit an experienced skew user for some mentoring. (Many turning clubs have list of people willing to mentor, sometimes on specific things. They will often have a variety of skews and grinds and some experimenting might help you decide which to purchase first. Cheaper than buying a variety first and then experiment! (Unfortunately, my tool acquisition addiction sometimes prevents me from giving useful "what is best to get" advice. :()
...using the skew for roughing...I don't understand that concept. Supposedly the skew should be "scary" sharp ... time spent sharpening, honing/stropping, etc. Why beat the hell out of the edge by roughing out a turning square?
I often pick the skew to rough a square blank instead of reaching for a SRG. I find it can be quicker and cut cleaner with less tearout (with some wood). Depending. Yes, start with sharp. No, like using the skew in general it won't dull the edge.
This is not to say I don't like SRGs - I keep several at hand, different sizes and shapes. But I often use them for spindles with coves/curves or curves transitioning to cylinders or tapers. (I really like the SRGs with a semicircular bottom transitioning into straight, vertical sides. When moving down the wood, you can twist the gouge to the straight section and use it as a skew - nice way to dance with the shavings. Thompson's - and others - are ground like that.) I also like the contenental type of roughing gouge which is used as a big, shallow, spindle gouge.
One thing about roughing with a skew - use one with a width appropriate for the size of the blank! Too narrow can make a big mess.
As often recommended, if you can spend some time with an experienced turner they could show the tradeoffs and you could try the tools and techniques for yourself.
Fair question. For me, it provides additional time in hand for the skew, making me more comfortable with it. It also depends on the project at hand. For something really long, or something with deep profiles, I'd probably go with the SRG. For most smaller stuff - boxes, hollowforms, finials, etc. I grab the skew. I'm skeptical that either provides an advantage of speed over the other for the rounding portion of the program - with the skew, it is simple to add a tenon for a chuck without needing a separate tool. As for the sharpening, I just grab the diamond hone, give the skew a couple of rubs and move along. For most smaller projects, I can do the roughing and the initial shaping with the skew, before taking a moment to hone before the final cuts - so there is not really any time lost either switching tools or sharpening after the roughing.
If I had to rely on one skew chisel, I would want a 1 inch wide by 1/4 thick. It can do pretty much everything. I have been going through a rolling pin phase, and I have been using the peeling cut for just about all of them. I am turning baseball blanks, hard maple. I did have some figured ones that had some big divots in them from tear out, and Had to turn the 3 inch diameter blanks down to closer to 2 inch. For those, I went with a continental style roughing gouge. For all the rest, I used a skew in peeling cut mode for all the rough outs. Same with the lidded boxes I have been doing, and I was starting with square blanks. For sharpness, I get first edge on a 320 CBN wheel, and for touch ups, I use a 1000 grit lapping plate. I always strop the burr off. Now, for sure, knocking the corners off with a skew can be hard on the edge. The thing with edges is that they start very sharp, drop a lot of sharpness right away, and then a "working" edge stays for a pretty long time, and again, this depends on what you are cutting.
Typically use two skews as my workhorses for spindle turning. A 1 inch sharpened burr up with the point to the left that I use for most skew work and a 1/2 inch sharpened burr up with the skew point to the right I use for detail. I don't have as much control in the skew point to the right or 'left handed' and need a smaller and more controllable tool.
I believe practicing both right-to-left and left-to-right is useful.
I do left-to-right one of several ways.
- I practice by switching hands - hard to get used to be perhaps best in the long run.
- Keeping the skew in my dominant right hand but doing some arm contortion to make the cut. Can be uncomfortable.
- Supporting the tip of the skew with the left hand. This works for both directions - I use this method a LOT for very thin spindles.
Left hand support: This set of pictures show left hand support for L-to-R in the first two photos, and the similar support for R-to-L cuts on very thin spindles. This support method has the huge advantage of controlling flexing and vibration in a thin spindle by supporting it with the fingers from the rear while cutting - "pinching" the wood gently.
One of my favorite skews, an oval, in the left photo, and a Thompson 1/2" in the other photos.
For the safety police, no, I've never cut or even scratched my thumb or fingers.
During cuts, the skew is supported firmly by my right hand, handle against my forearm, and right elbow pressed against my side. My left arm is steadied and supported by resting on the top of the lathe headstock. (I put carpet there for comfort.) The tool is moved with the legs, not the arms.
I don't use this type of support, nor is it needed, for larger diameters. I have both hands on the skew, the right as shown, the left in front of the tool rest.
For me, a 1" skew gets grabbed from the drawer more often than larger or smaller skews. Nice size, nice balance, works well for me for most things. If not, I grab the others.
Everyone who has told you what they like or use also has an array of projects that they like to do. Since your array will be unique to you, your favorite sized skew will also be unique to you.
If I were to suggest a skew to a beginning turner, assuming that they would be turning typical sized beginner spindle projects, not porch posts or Cindy Drozda finials, I would suggest a 3/4" or 1" size, with a curved edge. My thinking is that these are very versatile sizes, appropriate to the 3/4"-2" projects a newbie would be turning. In my view, the smaller skews are a little more nimble and therefore more likely to 'wander' into trouble, and the larger sizes would feel awkward with those sizes of spindle projects.
Ha, never heard it put that way! I may use that.
I think of smaller skews as more nimble and more likely to create 'wonder'fully fine detail. :)
I've been doing some practicing with a skew in hopes of getting somewhat good at using one - I think I'm getting better...
In hopes of expediting the process I've been watching some YouTube videos by Richard Raffin and Richard Findley. I was intrigued by Richard's use of a narrow (3/8") skew ground straight like a parting tool. I found a 3/8" Bedan that I pretty much never use and repurposed it to a similar skew chisel. I found I rather like it, although I need to grind the bevels a bit less steep. In the past I would normally reach for a 3/4 or 1 inch skew either straight or curved edge. The 3/8" skew seems to handle most cuts as well as the wider versions and doubles as a good sizing device for tenons - for MT chucks (thank you to John Jordan for making me aware of these useful devices!
Cheers.
Barry W. Larson
Calgary, Alberta, Canada eh!
I grind one 1/2" skew straight across. It's perfect for cutting tenons, very fast at peeling cuts.
However, I'm wondering about repurposing the bedan. The bedan I have is nearly square in cross section - seems a little thick for a skew but I admit I've never tried it. You mentioned regrinding it so it's a bit less "steep." By "less steep" do you mean grinding so the included angle is smaller? If your bedan is square in cross section wouldn't changing to a smaller included angle make the bevels on both sides overly long?
Do you know what included angle are you using now?
I do use the bedan sometimes as a wide parting tool, some curves, or for peeling. I remember long ago there was discussion about whether to use it bevel down or bevel up. Some in the US said they used it bevel down, used more like a scraper. For clean cutting, as the original use by the french experts, I think it's better used with the bevel up.
A thread about this:
John:
The skew Richard Findley sells as his signature skew chisel is 3/8" thick so i thought the square section of the Robert Sorby Bedan was perfect to experiment with. I do need to relieve the edges and regrind the bevels to closer to 22⁰ or a 44⁰ included angle. Right now I'm more like 19⁰ or 38⁰ included angle - if I'm measuring such things correctly.
Cheers.
Barry W. Larson
Thanks.
BTW, besides dedicated angle gauges, I use protractors similar to this one both in my little machine shop and turning area. Even a cheap one like this is quite accurate.
I use these protractors a lot. I generally prefer Starrett but for these my favorite is a Mitutoyo. Can't tell if it's any more accurate or precise than the cheap one I showed, but the engravings, weight, and materials simply "feel" like quality.
I watched some You Tube video about skew use, and the guy had a Richard Raffen Signature gouge, Crown I think. The angles on the cutting edge looked to be about 30/30 or 60 included degrees. Very blunt. He was doing okay, but not even close to an expert.
