I have been turning spindles the last couple of days, and have been having a lot of problems with vibrations. I originally thought that the issue was in the lathe, or with the set of the chuck on the spindle. But I've checked and rechecked those, and there is no issue with any of that. I then held the chuck firmly, and pushed and pulled a little on the blank I had in the chuck, and I could hear a bit of a click. On deeper investigation, it seems like my chuck jaws, may in fact be a little loose. I first pulled the blank out, and checked the tightness of every jaw screw. All were quite firm and the jaws themselves are not loose. It seems to be the slides that the jaws screw into, that are loose. Not a lot, but enough that it is causing a very problematic vibration, even with very short blanks (2-3 inches, which I've never had a problem with vibrations with before).
I am not really sure why the slides would be loose, but that seems to be the problem. I am now wondering if this is fixable...
