  • Congratulations to Guillaume Fontaine for "Méandre 2.1" being selected as Turning of the Week for August 25, 2025 (click here for details)
Stabilized Wood
It should be dry & dusty--so dust collectiom/capture while turning is important. Won't be shavings. Also, since the stabilizing process leaves it dry, expect the material to be brittle, so keep a light tough.
The stabilizing process imparts some degree of 'finish' to the stock. You might decide you don't need any other finish, depending on the use of the finished product.
Dean - the piece will be used as a handle for a pizza cutter. Thus, it needs a fairly durable finish. I suppose I could apply some polyurethane on it before it's turned to it's final diameter and see what happens. If it's not good, I can turn the less than desirable finish off.
Called the manufacture and ask. I've worked with Dymondwood (rip) and WSSI stabilized wood. It's a resin impregnating process. Most of it can be sanded with 600 grit and buffed if you choose to a high shine. No finish required and it lasts well. I have a knife or two with Dymond wood scales made years ago that still look great. Of course not all woods stabilize the same way and some use a different process. That's why I suggested a call.
Earl - thanks for the info. Any issues with applying a polyurethane finish that you're aware of?
Never used polyurethane on stabilized wood. Have used cyano-acrylate glue a lot with success--but i'd use a flexible version like MercuryFlex or Glu-Boost as they are less brittle than most "Super Glues". For kitchen use (wok handles, honey dippers, jar openers, etc.) i typically just use boiled linseed oil (BLO) or BLO-beeswax mix. It's all going to get wet and used--kind of like my favorite pans!!
