Stabilizing
Haubstadt, Indiana
@odie
Beautiful Jatoba crotch bowl. You said it started out at 20% MC and took 9 months to stabilize. For me if I have a bowl starting at 20% and rough I think it stable in a much shorter time. I usually check the weight once a week. When I get two weeks in a row with no change, I check it every day/couple of days for two weeks and if there is still no change it is stable to me. I have never to my knowledge had a roughed bowl take 9 months. I have mostly local woods vs. exotics if that is a difference. What do you call stable?
@odie
Hiya William..... :)
My process is a little different than yours in determining stabilization.....and, I find that, comparatively, I generally season my roughed bowls for a longer period of time than most other turners. Every turner must decide for themselves what process makes the most sense to their own particular needs.
My process is as follows: I weigh the roughed bowl monthly, and depending on the season of the year, an unchanged weight for either three or four months in a row indicate stabilization. I can see where my method might necessarily require additional time than your method.....but, it has been very successful for my purposes. Since this bowl blank was initially 20% MC, it is my usual method to anchorseal completely anything that meters over about 14% MC.....100% coverage. Some woods do release moisture slower than others, and the anchorseal slows it down further. This Jatoba crotch was fairly dense, especially because of the compressed grain in the crotch figure. I suspect a more straight grained piece of Jatoba might release moisture a little faster than this one did.
During the winter months, or times where there is a lot of rain, I've actually experienced a very slight weight gain in some bowls.....it's hard to predict which ones will gain weight, but others being processed at the same time might actually lose weight, or remain the same.
As you suspect, I've found that most domestic woods do stabilize quicker than most exotic woods, but there again, it's hard to predict what any one roughed bowl will log consecutive weights in their individual seasoning process.
I have had many bowls that have taken a year, or more to stabilize, and my world's record is 41 months for a Camphor Burl !!!!! o_O
Just in case anyone reading this thread is wondering, William and I are discussing this bowl of mine:
Turners get to hung up on asking this question, then expecting a general consensus answer that a majority agrees on. First off, each region/location is going to have different humidity levels and temp ranges. Different species of wood will require different considerations. The length of time, method for managing moisture loss, temp controls will be different for each region. Someone living in the desert areas will have a totally different process/time frame than someone living in the deep south with high humidity and temps.
The question was directed to Odie. I wanted to understand his process. The reason for the question was that I rough turned a bowl that was 20% MC in early November and I am now in the process of doing the finish turning. This is about three months vs. the nine months Odie took before finishing his bowl. I understand that different regions and workshop conditions will affect the time to dry. That is independent of the process used. I got my answer. He waits 3-4 months with no weight change, where I am about 1 month. Not looking for anything else.
Pretty much what I figured, William. :)
