Star Feature Ring
https://www.pinterest.com/pin/517632550900880340/
I want to make a feature ring like the illustration. Anyone have any ideas about how, who, where I can learn more about it?
It's a segmented bowl, with a contrasting segmented ring with either an inlay-or-thru (likely thru) star pattern. The segmented ring decoration looks like 10 pieces of light-colored wood (maple?) and contrasting star. I can't tell if the star is a single star or is also composed of segments, but I suspect segments.
Either a compound miter saw with a bunch of jigs for setting stops, or a table saw with a cutting sled is your friend for cutting the segments and assembling them.
Look up either (or both) Malcolm Tibbetts and Curt Theobald for some really good articles and/or books on segmented turning.
Hope this is helpful!
Doing the math - 360/5 = 72. Sp 72 degrees is your primary angle. I have a drawing which shows the angles. How you make your saw cuts to get them is up to you. Hope it helps.
It's just a minor detail, but the angle that you show as 107° should be 108°.
Each half point of the star is made by cutting triangles where the small angle at the point is 18° and the larger angle at the opposite end of the long side is 36°.
