Stitching Up A Bowl Crack
Ontario, CA
The bark inclusions on these 2 cherry bowls fell out during the drying process. I chose not to fill the void with epoxy and wanted to try something different. So I drilled small holes along the sides and am planning on using a thin braided cord to stitch them up.
There are several stitch patterns I could use and was wondering if anyone has any recommendations. Also, how would you deal with the ends, poke them in a hole and afix with CA glue? And what would be your choice of colour for the cord? I know this is subjective, but I’m interested in your thoughts of what would best complement the orange cherry colour.
I prefer a black or. Brown cord. As far as lacing g pattern I dont really have.an opinion. There are lots of choices that I have used in leather work.
Remember that in two months, that cherry bowl will turn much darker brown. Especially, if it's put near a window. I think I would go with a black cord to contrast with the browner wood that it's going to turn to. Browner? Is that a word?
I have used copper wire on several bowl/cracks. Rather than using a single wire trying to fit the holes, I use "art wire" from 20 - 26 ga and either braid it or twist multiple strands. The art wire comes in a variety of colors (finishes) from copper to silver, gold and bronze.
To twist it, anchor several strands in a vise, around a screw or something else and put the other ends in a drill. Holding tension on the wire, use the drill to twist it. Even with multiple strands twisted, it threads easily through holes and bends easily enough to give a nice tight looking stitch. I usually just use normal shoe stitch pattern.
Whether you use cordage wire or something else, I agree with the comments above to go with a darker color. I think a bronze color would nicely compliment the cherry both now and when it darkens.
Here is a honey locust bowl about 10 " in diameter that was stitched with 2 strands of 22 ga bronze wire twisted with a drill.
View attachment 36949 View attachment 36950
Nice effect Tim. With all these good ideas, I’m going to have to turn more bowls with cracks! No more discounts for cracked bowls
!8 years ago, I had a piece of curly Black Walnut that had a split in it, I decided to turn it anyway because of the curl in the wood, as normally I would not turn wood with a split in it, after I had turned that piece, I stitched the split with brass wire in a shoelace like cross pattern, there was no problem with the wire afterward, we still have that bowl, It was my first stitched bowl, but not the last one.
View attachment 37005View attachment 37006
I’m glad you kept that bowl Leo, looks good! I was very careful with my bowls to use compression tenons at every step rather than expansion recesses. This way, the chuck provided a little more insurance that the bowl would not undergo a rapid disassembly.
I know this is an old thread, but it's exactly what I have a question about. What do you do with the ends, whether cord or metal wire? I like the idea of lacing with copper, but I just end up with ugly, pointy bits at the ends. Suggestions?
Make the end hole slightly larger and double over whatever you use back into that hole. If using cord, a dot of glue in the hole locks it.
I don't know what cord color you might want, but I would avoid very light colors: white, beige, yellow, light orange, tan, etc. Even casual handling will get cordage dirty.
If you go the wire route, that can be cleaned, I guess, but will copper be able to be cleaned of tarnish without staining the surrounding wood if you use a metal polish?
