Usually, I attempt to eliminate any checking, or hairline cracks, just to be on the safe side......but, sometimes I take my chances with repairs. For large cracks and voids, I've been using epoxy for a filler. Epoxy tends to discolor in some cases, and requires masking off the edges to prevent any telltale residue that gets into the pores of the wood. With minutely small cracks, I've been using Titebond III simply pushed into the small hairline crack/check with only thump pressure......and, no masking. This seems to be a good solution.....and, pretty much remains undetectable.
My purpose is to prevent the hairline crack from separating over time. I'm not sure how long this kind of strengthening technique will last......hopefully forever.....or years, at least.
Here are two examples of hairline cracks repaired with TB III in the manner described above. I'm pleased that I can't see the cracks in these photos, but they are there. They can be spotted with the eye, if the observer looks closely.
I'd like to hear from those who have used this technique, or other methods of dealing with those pesky little hairline checks/cracks and unavoidable voids. Detailed responses are appreciated.......thanx
ko
ko
