• Congratulations to Tim Soutar winner of the May 2025 Turning Challenge (click here for details)
String Steady Jig
Grimes, Iowa
www.scrollsaws.com
I built some jigs to hold slender turnings using string and was wondering if anyone has a better way or idea to do the same type of thing. This one seems to work for the long slender turnings.
I just started turning in March so I still consider myself a newbe at this. I have more pictures of this jig on my web site. Actually there are alot of pictures of what I have been doing on the lathe.
http://www.scrollsaws.com
Rick,
I spent a delightful hour or so browsing your web site. I spent a lot of time viewing scroll saw related stuff before I made it down to your lathe work. (I liked the scroll saw info, but I prefer the other.) For a newbie, I can only say, "Wow!" You've turned a lot of stuff. Over 400 hundred boxes? From what I could tell from the pictures, it's all quality work. I think you've lost your newbie status.
Impressive string steady, Rick. Have you tried wrapping the string lightly around the piece before setting it? Higher risk of burn but more stability.
From that spindle, looks like you're doing fine though.
Welcome to the forum,
Dietrich
String Rest
I have not had any problem with the string burning the wood. Some I have started with just a few inches of wood out of the chuck then as I advance the wood, after turning and finishing a section, out I put the string rest on to stabalize it. On the picture I put the rests on backwards to get the string to the wood, the tool rest banjo kept me from sliding the string jig in closer the right direction.
String Steady
That looks great. I have seen string steadies described elsewhere but I like the open sided design of yours a lot.
On another subject, I have been trying to find your site again since I lost a ton of email in a crash at home. You were kind enough to give me some very helpful info on an old New Rogers scroll saw and I wanted to say thanks very much. I still have not sold it yet if you might be interested. I also have an old Companion oil driven saw and a similar vintage small Companion bandsaw. Conditions on these 2 Companions is not great though. Not turning related but I have been trying to find you for a while now.
Don
The string you are using looks like Jute. Is it? Or what is it? I would think the wrong material would tend to burn or score the wood.
String
I used what the package calls Twisted Nylon Twine. Used for things like Seine Twine, Plumb Line,Draw String,Chalk line, it also is size 21 210 lb. test.
I have not had any problems with the string marking the wood or the finish. I think because it is not wrapped or tied around the wood. It is pulled tight, but the wood really only rubs on one small section in 4 places.
This will not work for a tailstock hold on the wood, it is jut to lightly hold those long thin projects that tend to whip when the lathe is running. If you need a rock solid hold you still need to use the tailstock.
Creative thinking, Rick....
If it works, which it looks like it does, your ingenuity has solved a dilemma for anyone who does long thin spindle work. I don't do spindle work very often, but I could have used something like that when the Harry Potter craze was going full tilt!.....had a co-worker come to me and ask for a "magic wand" for his son's birthday. I did it, it turned out pretty good, but I was hampered by the whip of the long thin piece.
Your intricate scroll work is outstanding!
Keep up the good work.
....odie
In Kansas City at the AAW symposium last year a guy from France (I think) did a demo on tall thin (1/8th " thick) turnings up to 36" tall called Trembleurs. He used a similar string steady where the string was waxed and wrapped around the piece. He had a certain pattern of wrapping that worked very well. I don't remember his name.
Most likely Jean-Francois Escoulen. When you see him using the bedan turning long, thin objects, you will be humbled. An extremely nice person to take a class from.
Gordon
String Saedy
Jean Francois recommneds that you use a waxed sting for the steady. If it builds any heat the wax is there to lubricate it. I think that you can either wax your own or try a supply house that can supply it all ready waxed. Most laether workers will know where to find waxed twine. It is what they use for hand stitching.
A
Hi Sky,
I have shown the way I do this on my website, and explain the wrapping:
http://www.lavieenbois.com/tournage/frame_tour_eng.htm and select "trembleur" in the left menu.
you need to make "turns" (actually half turn) around the piece so that the rest is effective, I believe that's what can be improved to your (otherwise very well done) setup.
hope this helps,
Pascal
Very cool website
Pascal,
Thanks for the link to your website. It contains a wealth of information.
Pretty ingenious; and I wonder:
Have you tried (or experimented) placing adjustable dampening rings to "pinch" the strings at a point nearer to the workpiece to further enhance the anti-whip qualities of this tool?
String Steady
I have not tried pinching the string yet. So far I have used it for very small , but long, turnings and the way I show it has worked just great to stop that whipping of the end of the work. But I will sure keep that idea in mind if I use it for larger work. Thanks.
Sky said:
In Kansas City at the AAW symposium last year a guy from France (I think) ... I don't remember his name.
Might have been Jean-Francois Escoulen.
