I have an older Stubby 750 lathe that I have not used in the last couple of years. I started turning again now after about 4 months the on off box will make a pop noise and start smoking. I checked the box and everything looked good. I turned it on again and it worked for a wile and then the same thing happened. It then turns on again and the same thing happens.
Does anyone out there have any answers?
Thank you,
Les Bauer
Les@wcbl.com
St Petersburg, FL
Thank you,
Les Bauer
Les@wcbl.com
St Petersburg, FL
