Sweet Gum movement
Stanfeld, NC
I will soon start the rough turning on some Sweet Gum I scored. I understand that it moves a lot when it dries, so my question is: Do I need to leave material thicker than the normal 10% to allow for the anticipated warpage?
I'm pretty confident you can find its rate of shrinkage on the internet. I would not call that 10% guess as a normal allowance. You have to take size of the object and final wall thickness into consideration every time.
With gum, I would err on the side of more movement is more likely than less. I had a bunch of gum woods from early on when I started turning (2020), and over the years some of them moved a very significant amount, and entire blanks were extremely warped. They went from perfectly round to HIGHLY oval/oblong, for the blanks that survived longer than the first couple years (I received all of them fully waxed.) I think I still have two left, and both are quite oval compared to the perfect circles they originally were.
A couple of the original pieces I turned were given to family members, and once turned the warping was probably less significant than the blanks, however, they did still move quite a lot and I think some checking occurred on one of them. Neither of the originals sit flat anymore, and are also no longer round. FWIW, they weren't even freshly cut when I received them, they had been drying in their wax coats for a bit already.
This stuff can really move. So, either, err on the side of caution, or....let em dry for a while first, get a chunk of that movement out of the way, then turn.
Can find info on shrinkage and warping on the Wood Database. The entry for Sweetgum:
The nominal shrinkage/warping numbers are Radial: 5.3%, Tangential: 10.2%, Volumetric: 15.8%, T/R Ratio: 1.9
Maybe compare those to other species you have experience with.
The T/R (Tangential/Radial) ratio can be useful describe the warping. T/R for Red Oak is well over 2. Cherry is 1.9.
Their article on Dimensional Shrinkage explains:
But how the wood moves and warps as it dries also depends on other factors - I think the biggest for bowls is grain orientation (commonly straight face orientation), proximity to the pith, figure, wood from a straight trunk vs a leaning limb, etc.
The best practical resource I know of for all this is R. Bruce Hoadley's book "Understanding Wood".
I haven’t experienced major movement from the Sweetgum I’ve worked. I aquired quite a lot from a neighbor who had to take their large old tree out. It had broken his sewer line. Some, I turned immediately. Other logs sat under tarps,,tucked in for a few months. The wood that sat under the tarps was, I think, the most beautiful. It had generally darkened. The ends of the logs had turned black, with just a bit of slime. Scared me just a little. The wood inside though was simply spectacular. Rich golds, greys, blues and reds. Really gorgeous stuff.
I abide by the 10% rule for roughing, and cut almost all of that away. It hadn’t moved much at all. Red oak is the only wood in where the 10% wasn’t enough. A few pieces couldn’t be cut round without the inside becoming larger than the outside! Others, I had no creative reshaping. Only one profile possible.
Enjoy the Sweetgum experience! It’s great stuff to work with.
I've turned quite a bit of sweet Gum over the years, my property is covered with them, but don't recall movement being a serious issue. Not so more than typical. As Marc says, some of the pieces I've turned have outstanding color to them. Others not so much. It seems to really vary from tree to tree and a bit of aging.
