Switch air cleaner
Brandon, MS
threeringswoodshop.square.site
This has not been a real problem but would like it more convenient. I have two air cleaners mounted in the ceiling and would like to have them both work with wall switch. Both can be turned of via wall switch but the Jet will not turn on via wall switch. Starting construction on new shop I hope this week and it will be higher than my arm reaches. Question is is there a way to wire the Jet to turn on with remote wall switch? Yes it has a remote which works to about 8 feet.
If you want a really annoying set up, mount 2 jet units together. They use the same remote, but often only one turns on. Then you press the button again and the first one turns off and the second one turns on..... aaaagh.
