Trying to get an organized picture of which situations lean toward a dead-center tool rest, or others to a slightly raised tool rest. I adjust it occasionally by feel, but would like to have some insight. Thanks.
I never worry about 'perfect' height, mostly because it isn't critical, and I can adjust without thinking about it. When I took a 3 day workshop with Stuart and Allen Batty, Stuart would come by and adjust my tool rest for me. Since I tend to hold my gouges level when cutting, I prefer the rest to be pretty close to center height. Easy to angle the handle up or down a little so I can be cutting closer to the center line. When cutting with dropped handles, it can be a bit lower than center with no problems. With scrapers, since you always want them angled down a bit, I tend to have it close to center height on the outside, and a bit above center when turning the inside. This aids what Al already commented on as to how scrapers should cut a little below center on the outside, and a bit above center on the inside.
Now, I know all about stop collars on the tool rest posts. Small pieces of PVC or end grain hollowed out pieces that keep the tool rest at the perfect height. I do keep one on my McNaughton tool post, but other than that, it seems that I move them around and up and down a lot. I do like the idea of what Lyle Jamieson does with his tool rests where he has a threaded post and a big nut on it for adjusting height. Simple to raise or lower a little bit.
It depends a lot on two things. [snip] Be more concerned with where and how the tools is cutting and then adjust the tool rest so it's comfortable for you.
Proper tool rest height is such that the distance between the top of the banjo post and the the bottom of the tool rest is very slightly more than the knuckle on my index finger. Shall I bring my index finger to you, or do you want to mail me your banjo and tool rest?![]()
How 'bout if I mail you my index finger and new tool rest, and you place a fine mark at the "perfect" place on the post?![]()
[snip] So I did away with that idea and started trying to understand why I move the tool rest. Some day I plan to do a video on just that but since I'm still without a shop for at least another 6 weeks or so it will have to wait.
