Tiny skew
I have no need for a tiny skew since I can do a skew like cut with the wing of just about any gouge and that is usually one that I have in hand.
Nice one John, have thought of making one also.
No matter what size your skew is they still work the same. This is not my smallest skew.
The smallest skew I have is 1/4", and I rarely use it. At an AAW symposium years ago, I watched Alan Lacer turn a small piece with (IIRC) a 1-1/2" skew. But I don't have his skill level, so I generally use a 1/2" skew.
I use quarter-inch and half-inch round skews. To facilitate sharpening, I use the jig shown here to hold the faces of the skews parallel to the rim of the grinding wheel. The jig has a barb next to the through-hole for each size skew. There is a corresponding hole in the inner end of each handle.
I used some scrap Corian for my jig, but a piece of hard wood would work as well.skew..jpg
I just sharpen by eye which is much easier with CBN wheels because they run so true. My mini skews are initially shaped by hand on a 600 grit hone under my 20x stereo microscope. I have skews down to .008".
Denis can you please explain I am having a mental aberration
Brian, I guess I was not clear. Consider the upper shew in the picture. If you pushed the skew to the left, the barb would enter a hole in the end of the handle, preventing any rotation of the skew.
John, you have me beat. My smallest is a 1/8 in flat skew. Regarding sharping of a round screw, it is analogous to the sharpening of a gouge. If you are good at it, freehand sharpening is fastest. Otherwise jig sharpening is the way to go for most turners.
Sharpening a round skew freehand raises another issue: If you miss your aim and grind off one of the corners of the cutting edge, you will have to grind down all of the rest of the edge to regain the original shape. This can be waistefull of time and money. With a gouge, an error usually requires only a bit of blending in of the grind.
All you need is a light touch. You can feel when your on the bevel if you use a light touch. Especially with the CBN wheels
