To burnish or not to burnish your burr?
Canisteo, NY
Do you utilize the burr straight from the grinder when you’re using a NRS or should I invest in a burnishing tool? Seems like an inexpensive way to get more time at the lathe.
Baltimore, MD
I bought a straight piece of carbide rod on eBay. I think about 1/4” x 2” and mounted it in a turned handle with epoxy. It makes a great burnisher and gives me a nice burr after and between grindings.
Yep, like Lou, I hate buying stuff when I can make it easily enough ..carbide rod, or even a piece of HSS bar stock (provided it is as hard or harder than your scraper steel) mounted in a flat piece of wood, with a pivot point for scraper suitably far away enough from the rod, and you have a nice scraper burnisher.
Ponsford, MN
I was first introduced to burred scraping in 1989 at a Pro demo by Del Stubbs. Dell used an india slip stone to form the burr which worked surprisingly well but I have since developed my own method of honing the edge first then forming the bur with a hand held burnishing tool.
These burnishers are made from scrap CNC router 1/2" shank bits the advantage is the shank is polished which I feel is better than the mate finish on carbide blanks. The hand held feature allows use on any configuration and with practise you can better apply the right amount of pressure to get just the right amount of burr.
I have several burnishing tools around the shop for both turning and flat work tools. 3/16 by 2 inch long carbide rods. I burnish the burr on my shear scrapers and my NRSs. My preferred NRS at this time is one that is ground 25 on top, and 60 on the bottom. I don't go through the process of stropping off the burr. I use the grinder burr till it is gone, then burnish down and back up. I do have one that is 45/45, and I need more practice with it. My theory is that you need a certain amount of metal under the burnished burr to support it. If I try to burnish a 30/30 skew for a burr, the edge seems to fracture. All of my shear scrapers are ground to 70 degrees, and like the NRSs, I use the grinder burr till dull, then burnish down and then back up. This process, on both tools can be done 2 to 4 times maybe before I hone off the old burr and grind a new one. With the NRS, that burr is gone in seconds. As Tom Wirsing said, "If you have to push at all, the tool is dull." I have experimented with honing a burr on my scrapers, which include my coring tools. While it does work, I get a better burr with a coarser stone. Some hone up and down, some go sideways. I think I prefer the sideways version. In all cases, the burnished burr lasts a lot longer than the grinder burr. You can burnish a burr on M2 hss with the traditional burnishing tools used for card scrapers, but I had much better luck with the triangle ones than I did with the round ones. I found it almost impossible to burnish a burr on the M42 and V10 tools with standard burnishing tools. I do not have one of the Veritas burnishing tools that you screw down to your work bench. Not positive, but I think they work best for standard scraper bevel angles, in the 60 to 70 degree range. Don't know how they would work with a NRS. With the proper burnishing tool, you do not need a lot of pressure.
Spartanburg, SC
Yeah, I got one of those carbide rods and mounted it in a handle. When I'm cleaning up and refining with my NRS, I'm constantly pulling that burr back up after a few passes. When that starts to yield diminishing results, I go back to the grinder.
Canisteo, NY
Brilliant, and it gives me a reason to turn more handles
Bainbridge Island, WA
I got a used carbide twist drill bit from work. Chuck it up and drill into a handle. Reverse the bit out, put in a little epoxy. Drill the bit back in. Release from the chuck and it is ready to go. There are many types of hardened drill bits that might work.
Roger Wiegand
Wayland, MA
www.carouselorgan.com
I burnish my burrs, much longer lasting and much more control over what you get. Lots of worn out solid carbide tools out there that can be flipped around with the sharp bits inside the handle and the butt end perfect for burnishing. You really do want a carbide burnisher for modern very hard steels like M42-- your old screwdriver won't do it.
La Grange, IL
Was buying something from Veritas (IIRC) on line. At check out shipping was coming to $15, but if I spent $12 more it would be free. Searching the catalog I found a hand held carbide rod burnisher for $12.50. So I essentially got paid $2.50 to "buy" mine. :)
Making your own stuff gives you an additional creative outlet, and sometimes you pioneer new methods as a result!
Mounting in a flat surface with a pivot point is the way to go. It gives you much more pressure to form burs. For me, this is an important aspect of creating burs on my homemade scrapers with steep grind angles...
Adelaide Hills, Australia
Like most of us, I experimented with various forms of burnishing and settled on diamond cards. After all diamond is harder than any of the turning tool metals we use. Like Reed, I begin by using using whatever burr forms straight of the grinder and then refresh a number of times at the lathe before returning to the grinder. I have found that maintaining a high polish on the upper bevel improves the quality of the burr formed. I do that with a rag wheel charged with honing compound... it's extremely quick.
If I was using a burnishing rod I would get one of these (just the rod) or make one to match my requirements. You would need some form of diamond wheel to do that with.
