Well, any box over about 1 inch diameter, can move enough so that removing the lid can be a problem. If you keep it at your home, in the area where you turned it, it is less of a problem. If you move to a drier environment, it can move enough to create problems. If you use two different wood species, you can also run into more problems because the woods may/will move differently according to relative humidity. I do make some over sized boxes, 5 or so inch diameter. I prefer a long tenon, like about 1/2 inch, and always make it from one piece. It can move, but the base and lid should move the same amount, which means you might not be able to spin it all the way around, but it 'should' still be easy to remove the lid... Emphasis on 'should'....
