I have two CBN wheels, an 80 and a 120. I'm happy with them execpt when I want to reshape a tool. It simply takes a long time on the 80 grit wheel. What do you use when you want to remove a lot of material on a gouge?
Be careful, a screw driver is probably a cheap steel which will clog up your cbn wheel and ruin it.Could a belt & disc sander work for this and if so what type of belt would you suggest? Aluminum oxide seems like the choice from what I've read so far.
I made a point tool out of a screwdriver on a 220grit CBN wheel last night but only used the square side of the wheel.
Debating a second grinder because of what the OP said...
For sanding metal, Ceramic lasts the longest, then Zirconium, then Aluminum oxide. As I mentioned I use very coarse grids to remove a lot of material. I usually sharpen with 100 or 120 ceramic belts @ about 700 sfm.Could a belt & disc sander work for this and if so what type of belt would you suggest? Aluminum oxide seems like the choice from what I've read so far.
