Tormek Gouge Jig SVD-185
Status
Not open for further replies.
Leland, NC
The Tormek Gouge Jig SVD-185 is new in the original package.
Sharpen your gouges and turning cutters with ease using the SVD-185 jig from Tormek. This jig allows you to shape and sharpen fingernail-shaped turning gouges and roughing gouges along with bent carving gouges and V-tools. Maintain your tool’s exact shape and create a perfect sharpened, honed edge. The jig can fit tools up to 1 inch wide.
This jig enables you to sharpen to the gouge’s exact shape and remove only a fraction of the steel. The end result is a perfectly honed and polished edge. Included with the jig are a shaft for turning cutters along with a special recipe label and pen that let you note settings for your tools. The jig can accommodate tools up to 1 inch wide.
The jig comprises a tool holder which runs in a sleeve. The tool is aligned with a disc and tightened with a knob screw. There is a washer for wide gouges. The stop ring can be set for a convex bevel with a screw. The tool holder can be set in any position from 0 to 5 with the 5 mm allen key. The setting can be noted on a special recipe label, which is attached to the ferrule. A special pen, which works on these labels is included. For turning cutters, there is a shaft with a mounting screw and a 2.5 mm allen key.
Currently on eBay for $87.39. Asking $45 OBO plus shipping.
Rick Bucker
rickb5078@yahoo.com
Cell: 217-620-0221
Status
