Turning a Stool Seat
Arlington, VA
I'm making a stool and am thinking of ways in which I can turn the seat on the lathe. I'd rather not bore a mortise and instead leave the top and bottom of the seat flat. Picture below is similar to my plan.
Would appreciate your feedback on this technique. the blank will already be flat from a planer.
-I'd mark the center of the blank on the top and bottom and CA glue a 1-1/2 x 1-1/2 x 1/4 sacrificial wood block at the center.
-Mount the blank between centers using a spur drive and live center, making sure that the blank is perpendicular to the turning axis.
-Turn the blank round, and bevel the top and bottom.
-Remove the blank, and saw/chisel/block plane/sand off the sacrificial blocks.
I've thought about gluing a tenon to the bottom of the blank and remove it when finished, but it'd have to be ~3" dia and 3/8 thick. More difficult to remove.
Any better ideas?
Double faced tape to a faceplate may do the trick. I have also heard of gluing a removable glue block with a piece of a paper bag glued between the glue block and the work to help separate the glue block afterwards.
I'd just simply screw a faceplate to the bottom side of the seat, since it is already planed flat, and turn the seat to completion in one step. That's the primary purpose of a faceplate. Screws with 1/2" to 3/4" penetration are sufficient, you aren't hollowing a bowl blank so your cuts will be relatively lighter. Use the fattest sheet metal screws or wood screws that fit thru the faceplate holes, no drywall screws- too brittle. A single screw screwchuck, with 1/2" screw penetration, will be sufficient, too, see Richard Raffan for this. (He actually has a turned stool project on youtube, if I recall.) Sand the bottom to your desired smoothness before mounting the faceplate, and that area is done. (If you would rather not see the screw holes afterward, fill them with wood pegs afterward.)
If you are turning oak or other woods with tanins, use stainless steel screws, and line the face of the faceplate with masking tape or packaging tape, to lessen staining of the wood from the tanins and steel reacting to each other.
I know lots of people have success making joints for turning processes with CA glue, but I simply don't trust it here to resist the shearing loads of the turning process. It has no give to shock, it just simply breaks, not what you want happening with something like a catch of rhe cutting tool.
I've made a couple footstools like you show- fun projects. Mine are short like those, with relatively thick tops (1-1/4" to 1-1/2" thick) so the leg mortice gives a lot of structural support, so I did not need rungs between the legs. And I also slotted the top of the leg tenons for wedges, which add a lot of strength to that joint.
If you would like to add a cushioned/upholstered top for comfort as a footstool, Amazon has lots of affordable bar stool cushion tops that have simple elastic "cuffs" to keep them in place on the stool top. They are made for a few different diameter stool tops. Enjoy!
I atrach a wasteblock to the front using CA with accerator. Then I turn the bottom and cut a mortis for my chuck. Then I turn details or texture into the bottom of the mortis. Then I use a chisel to break the bond of the CA. Its not the wedging action that breaks the bond its the impact so fit it hard. Then I mount it on my chuck and turn the topside of the stool
Its fun to use an air brush to add flowers ir other details to your stools. Sometimes of course you get a little whacky.
You’ll find a stool project as part of the 4 way challenges from Raffan, Tomasic, Peace, and Angelo. The different perspectives may help you with your decision.
I liked the design of Tomasic’s stool. I would turn a tenon like he did, then use a flush cut handsaw to remove and sand the bottom smooth.
On a similar project I “permanently” screwed a face plate to a round piece of melamine coated plywood. Since the surface is flat it attaches easily to the workpiece with double sided tape. I’ve used that many times in situations such as yours.
A vacuum chuck system is by far the best method. I even use it to drill and ream leg mortises on the lathe. If I didn't have the vacuum system, I would use double sided tape, or hot melt glue.
Shop made vacuum chuck.
All of these stools, except for the live edge one, were started on the lathe using my vacuum chuck. Some received additional carving after the initial turning. I also turn table tops, some as large as 3' diameter, on the outboard side using a vacuum.
Well, for me, to turn the top side and profile it, I would drill a recess into the bottom and turn it that way, then fill the recess after you are done. You could turn a waste block as well, NOT PLYWOOD! Legs will not be easy. I prefer a fairly even taper. Some of those legs just look too bottom heavy. Drilling the stretcher holes will be the difficult part. I did make a one legged stool once. Supposedly a good thing for some one who is autistic. It helps them to sit still. Also called a "milking stool".
Larry, half blind dove tails on the little step stool?
Thanks for the ideas!
I don't want to show any evidence of turning, so screws and mortises are out, for this project.
Also, the blank is Black Locust. Pretty dense and I imagine it'll be hard to turn. Rethinking my idea of using a spur drive/live center, as it won't have a very large contact area. Thinking that I might make a sacrificial tenon, clamped in my 3" chuck and glued to the blank.
Any thoughts on using CA glue, or putting a piece of paper between the sacrificial tenon and the blank so it'll be easier to remove?
I have made a couple of stool seats on the lathe. Turned a spigot on the bottom side and used that to hold in a chuck.
Then turned the spigot off like one does on a bowl. Might of had a 3/8" stub to carve off by hand and sand. Worked just fine.
Since you are using a finished thickness board.....I would just glue a turn away tenon the same way. I would just use Titebond glue.
Black Locust is very hard, but actually turns pretty nicely. Sands out nicely also. The dust of the Black Locust is not good for the lungs.....wear dust protection.
Keep it simple. Something you already know how to do with the spigot.
One other thought, Ken. When you mount between centers, it's very hard to get the face of the blank perfectly perpendicular to the lathe axis. That means you end up facing off each side to get them square again, which would negate the value of using the planed surfaces as your final ones. It's not impossible to do, but I think you'll need to have an effective technique figured out, in order to succeed.
Thanks everyone for the ideas.
I mounted 2x6 square block to one side with Titebond and a piece of newspaper in between, then screwed a faceplate to that block. I put a small piece of wood under the live center to protect the seat. It turned really easily and with a few taps with a chisel, the block came off cleanly. After a little sanding, there will be no evidence of it being turned on the lathe.
A few lessons learned:
-newspaper + Titebond I worked really well
-placing the faceplate exactly in the center of the piece was tough. I drew line-up lines on the block and the blank, but my faceplate has 6 screw holes evenly spaced, so only two holes lined up with the perpendicular lines I drew on the blank. Off by maybe 1/16". Noticeable when on the lathe, but it won't be detected when I complete the stool
-should have also planed the sacrificial block before gluing up. I thought it was parallel, but it might have been off just a little bit. I shimmed the faceplate to make the locust blank more perpendicular to the lathe axis, and thus the bevels more consistently deep. I might be off by 1/16" and that won't be noticed, I'm sure.
Thanks again for the ideas, everyone!
First, bravo. Well done and you used the technique I would have. I'm very pleased that you liked this solution.
If you are interested in aligning a faceplate more accurately, I suggest that you build a faceplate alignment jig. Mount a 2X2X4 inch block of wood in a chuck, turn an inch long stretch the diameter of the inside of your faceplate. Find a metal rod longer than the height of the faceplace plus the flange, plus the thickness of any glue block (I use a big nail, but anything will work) drill a hole through the block of wood to match your metal rod. I put a "handle/flange" above the part that goes into the faceplate threads (1" in diameter larger and 3/4" wide is my suggestion). Part off your brand new jig. Sharpen the metal rod to a point and you're good to go. If you're using a glue block then you'll need another hole through the glue block. This is also a good time to face off the glue block. To use, put the point of the metal rod on your center point and you are perfectly aligned.
Congratulations again and safe turning.
Great tip, Jim. Also you remoinded me that I could have/should have faced the glue block once it was mounted on the lathe to help make the blank perpendicular to the lathe axis!
Continuing to learn
Do you have a drum sander? That's my go-to to flatten blocks and blanks and make both sides parallel. I keep 60 grit paper on the drum.
First mount the waste block on the lathe then turn it round to say 6" diameter and follow by turning the glue surface flat (use a straight edge to check the surface). On the seat blank find the center and with a compass draw a circle slightly larger than the waste block and use that to locate the waste block. I would also use heavier paper like paper grocery bag.
